4.5 Running rough?
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 17 times
Been thanked: 77 times
Re: 4.5 Running rough?
Post by David M » 07 Dec 2017 07:43
That will work. You now need to check the timing and the air/fuel ratio and you should have a different vehicle.
Home Town: .
Current 4x4: 2000 Nissan Patrol 4500GRX
Has thanked: 87 times
Been thanked: 117 times
Post by SJC » 07 Dec 2017 08:15
Must say, it already feels a lot better than what it use to. It was " stuttering" a bit before I blocked it off... :salute:
David M
Home Town: Midrand
Post by David M » 07 Dec 2017 08:54
SJC wrote:
07 Dec 2017 08:15
Once you sort the settings you will find you gain a lot of power and smoothness at the bottom end of the rev range but it will no longer take off at 3 400 rpm as it is not getting the extra air through those holes.
David M
Home Town: Midrand
Post by David M » 01 Feb 2018 14:51
There is good news and bad news.
Most of our 4.5's have a problem with pinging and we can mess around with different octanes of fuel, intakes, heat reduction etc etc.
The good news is that the problem is the worn distributor and replacing it turns your vehicle into a machine with no pinging whatsoever, anywhere under any load.
The bad news is that the replacement from Nissan is R 15 k. Importing from Aus is more expensive and Partsouq in the UAE does supply but has no stock which you should land here for about R 7 k.
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Has thanked: 70 times
Been thanked: 90 times
Post by Wilkie » 01 Feb 2018 15:18
David M wrote:
01 Feb 2018 14:51
have you got a Nissan part no for that.....
Has thanked: 282 times
Been thanked: 104 times
Post by Kagiso II » 01 Feb 2018 15:23
what about MARINUS ?? he should have a more affordable one?
David M
Home Town: Midrand
Post by David M » 01 Feb 2018 16:04
Kagiso II wrote:
01 Feb 2018 15:23
Nope. Checked. The Ausiies also bitch and moan as they pay about Aussie dollar 1 000 for them.
David M
Home Town: Midrand
Post by David M » 01 Feb 2018 16:05
Wilkie wrote:
01 Feb 2018 15:18
David M wrote:
01 Feb 2018 14:51
Will get it. Forgot the old one which is in the box at Graham.
Has thanked: 252 times
Been thanked: 337 times
Post by Peter Connan » 01 Feb 2018 18:54
Can't one refurb it?
Grind the shafts and bush it up?
David M
Home Town: Midrand
Post by David M » 01 Feb 2018 19:37
Peter Connan wrote:
01 Feb 2018 18:54
Yes but the tiny coil pack is now 20 years old and the optical sensor becomes slightly wonky and these can't be refurbished.
Mine was out by almost half a tooth due to wear so precise setting was a problem and you can feel the difference in the intensity of the spark being provided by the new coil pack.
