TD42 engine replacement options
African_mzungu
Full Name: Matthew C Blair
Nickname: African_mzungu
Home Town: Kalumbila
Current 4x4: 1998 GU 2.8 Nissan Patrol
Post by African_mzungu » 06 Oct 2017 11:38
Hi all,
I am looking for options to do a complete engine change of my 1998 2.8 GR Diesel, TD42. Does anyone have suggestions on a good replacement model, and/or sources?
Cheers.
Stefaansie
Full Name: Andre Vorster
Nickname: André
Home Town: Benoni
Has thanked: 9 times
Been thanked: 6 times
Re: TD42 engine replacement options
Post by Stefaansie » 06 Oct 2017 13:20
Hi Matthew,
Be patient, most of the fundi's are out of reach this weekend. I'm sure you'll get a reply by early next week.
'96 SGL-D PATROL (GQ)
ECHO 3
'07 SUZUKI BOULEVARD 1800
'06 YAMAHA 700 RAPTOR
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Swakopmund Namibia
Current 4x4: None
Has thanked: 85 times
Been thanked: 96 times
Post by JoshJ » 06 Oct 2017 13:30
For a TD42 you can pm Michael Steyn. The notification should reach him when he has signal on baboons :biggrin:
Being alive is a Blessing!!
Joshua
Has thanked: 280 times
Been thanked: 356 times
Post by Peter Connan » 06 Oct 2017 14:03
Very sorry to hear your car is still giving you issues.
I thought the 2.8 is the RD28?
Unfortunately, that engine was never available in the Patrol here in SA, so very few of us have any actual experience with this engine.
In terms of actually getting the engine running, the TD42 must be about the simplest engine available short of an old tractor. All it needs is a wire to open the fuel solenoid, an earth strap and a power lead for the starter.
On the other hand, I have no idea whether everything fits...
Has thanked: 557 times
Been thanked: 291 times
Post by Tinus lotz » 06 Oct 2017 16:17
Hello yes it fits but you might need a td42 bell housing als :wink: o ....it bolts on no issues speak to Michael he can help
African_mzungu
Post by African_mzungu » 10 Oct 2017 07:18
Peter Connan wrote:Very sorry to hear your car is still giving you issues.
Thank Peter,
From what I understand it should be one of the most basic engines to repair or diagnose- I have the option of sending the head all the way to SA for full check up, and if there is an issue then I can get a reconditioned/new head back, but time is a factor here- being the tail end nowhere in Zambia its all a bit tricky when it comes to logisitics!
I will double check that, I think you are right RE RD28.
Cheers.
Users browsing this forum: offroadbiker and 1 guest
