Bonnet for my 2008 Partol
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
Home Town: Kensington, Jhb
2011 2.5 Di Pathfinder LE
Home Language: Afr & Eng
Been thanked: 35 times
Post by mvcoller » 11 Sep 2017 23:04
I've had a bigger front mount intercooler fitted to my 2008 3.0 TDi Patrol, so I no longer need the scoop on the bonnet (it is now blocked to stop excess underbonnet air). This blocked bonnet scoop now make my Patrol look a bit like a 1965 Cortina 1300 would - with a rear wing!!
I now want a plain bonnet, a la 4800i
Does anyone know where I can find a decent used one, preferably in silver, but actually, any colour will do.
Has thanked: 102 times
Been thanked: 90 times
Re: Bonnet for my 2008 Partol
Post by offroadbiker » 12 Sep 2017 09:19
Best bet would be to contact David in Bela Bela.
Has thanked: 540 times
Been thanked: 277 times
Post by Tinus lotz » 12 Sep 2017 14:31
Gaan goedkoper wees om die gat toe te maak :mytwocents:
Current 4x4: PATROL COLLECTION
2004 4.8 GRX "Tinkerbell"
Has thanked: 101 times
Been thanked: 71 times
Post by hugejp » 12 Sep 2017 15:07
Why not just block the hole from underneath & keep the scoop? Effectively making the scoop a dummy...
mvcoller
Nickname: mvcoller
Post by mvcoller » 13 Sep 2017 21:20
Hugejp,
I thought of that, but it will fill up with rubbish and will be difficult to clean. I have blocked them, with neat aluminium covers on the inside on the vertical plane. This however makes it very visible that it has been blocked and looks really silly
Maybe do as Tinus suggest will be the best option....
Post by Tinus lotz » 17 Sep 2017 12:05
Micheal het n oom wat uitmaak praat met hom.....vertel eers meer van wat jy met jou 30l gemaak het?
Has thanked: 269 times
Been thanked: 100 times
Post by Kagiso II » 17 Sep 2017 12:50
I have a scoop on iNyathi 's bonnet. BUT no inter cooler [maybe must buy up Malcolm's old inter cooler ???]
Back to the scoop on iNyathi's bonnet -- Up to 140 KMH it makes as little as NO difference on the under bonnet temperature or pressure.
At one time I blocked it off and closely monitored the water and engine temp on the MADMAN .. and really, it made NO difference. .. I took the towelling out and the duct tape of.
Since I have been running it op as when I bought iNyathi
MALCOLM .. do you still have that top mount I C ??
Post by hugejp » 17 Sep 2017 13:33
Kagiso II wrote:I have a scoop on iNyathi 's bonnet. BUT no inter cooler [maybe must buy up Malcolm's old inter cooler ???]
PM gestuur Oom!
mvcoller
Nickname: mvcoller
Post by mvcoller » 05 Oct 2017 22:27
Ja, Mac, ek het hom nog hier by die huis.
Tinus,
Cirrus het my voertuig gebruik om 'n groter intercooler kit wat voor, agter die grille, pas te ontwerp. Die nuwe een is ongeveer 300m hoog, 400mm breed en so 60mm dik.
Home Town: .
Current 4x4: 2000 Nissan Patrol 4500GRX
Has thanked: 87 times
Been thanked: 117 times
Post by SJC » 16 Dec 2017 12:07
mvcoller wrote:
11 Sep 2017 23:04
Did you ever find a bonnet?
