Tappet cover cup washers
Iaan du Toit
Full Name: Iaan du Toit
Nickname: Iaan
Home Town: Sabie
Current 4x4: Patrol pickup
Patrol 4.8
Hilux D4D
Has thanked: 9 times
Been thanked: 28 times
Post by Iaan du Toit » 08 Jul 2017 21:37
I am busy repairing a Patrol 4.2 pickup. Some of the cup washers that hold the tappet cover in place was missing and Nissan could not supply.
After a bit of head scratching and some time on the lathe I came up with the following plan that worked 100%.
I formed the cup washers from the thin metal part of conventional bonded washers pressed with a top and bottom die.
A standard 20 mm water tap washer fits perfectly. I had some stainless steel washers that fit on the top of the rubber tap washer.
I found it easier to form the cup washers in two stages.
As I am not good with words I will let the photos do the talking.
Wat ek is, is net genade.
Wat ek het is net geleen.
Has thanked: 163 times
Been thanked: 279 times
Re: Tappet cover cup washers
Post by Michael » 09 Jul 2017 07:58
Iaan, dis briljant!! Dankie dat jy dit deel, want dis nou maar een item daai wat altyd vermis gaan
Has thanked: 570 times
Been thanked: 296 times
Post by Tinus lotz » 09 Jul 2017 10:39
Netjies mater daai lyk reg :blonde: :salute: :salute:
Has thanked: 113 times
Been thanked: 93 times
Post by hugejp » 09 Jul 2017 11:32
Baie mooi!
:thumbup:
Rhett
Nickname: Rhett
Home Town: Heidelberg
Current 4x4: 2004 Nissan Patrol 4.8 GRX
1980 Toyota Land Cruiser HJ47
Has thanked: 117 times
Been thanked: 46 times
Post by Rhett » 09 Jul 2017 14:16
The ingenuity of us Patrollers amazes me! Good stuff!
Rhett
Has thanked: 265 times
Been thanked: 261 times
Post by ricster » 10 Jul 2017 08:53
Well done !!! Those look the part for sure !!!
