EGT
gupster
Full Name: Barry Guppy
Nickname: Baz
Home Town: Hibberdene
2005 Nissan Patrol 3.0 GR
Has thanked: 130 times
Been thanked: 30 times
EGT
Post by gupster » 08 Apr 2017 17:06
Hi all. I am hoping someone can shed some light on this.
I have not used my Patrol for a couple of months and yesterday I took it out for a spin. I immediately noticed that the EGT's went up very slowly and never went passed 250 C. even when doing 120Ks an hour. They also moved down very slowly too. I dont think there is anybody here in Hibberdene to help me and am hoping I wont have to take the Patrol to Durban to sort it out. Its a 2005 3.0l and the madman was installed over a year ago.
Many thanks.
Have Troll, will travel.
Has thanked: 569 times
Been thanked: 295 times
Re: EGT
Post by Tinus lotz » 08 Apr 2017 17:52
Does the performance feel correct?
Has thanked: 163 times
Been thanked: 279 times
Re: EGT
Post by Michael » 08 Apr 2017 21:04
Thats very low EGT's. Is it low on power?
Ds J
Full Name: Jaap Steenkamp
Nickname: Ds J
Home Town: Stella
Current 4x4: 1985 Hilux 4x4
Has thanked: 1 time
Been thanked: 8 times
Re: EGT
Post by Ds J » 08 Apr 2017 21:55
The Patrol was striking that Zuma must go ;)
gupster
Nickname: Baz
Re: EGT
Post by gupster » 09 Apr 2017 07:43
Hi Tinus and Michael. The trucks performance has not changed at all so I suspect it is directly related to the EGT. I had always watched the temperature like a hawk and never noticed anything change except for now, a drastic difference.
Re: EGT
Post by Tinus lotz » 09 Apr 2017 08:33
Bad earth or corroded connectors between madman and thermal probe wire but shouldn't be constant if faulty????
:think: :think:
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Been thanked: 74 times
Re: EGT
Post by ChristoSlang » 09 Apr 2017 10:52
Was it always this low?
Do you measure before or after the turbo?
Christo (the snake man)
gupster
Nickname: Baz
Re: EGT
Post by gupster » 09 Apr 2017 20:18
Hi Christo. The probe is before the turbo, I think between 2 and 3 cylinders. It always moved very rapidly up and down and I was able once to get it just below 600c going flat out up a hill. However, I cant compare apples with apples as I have never watched the temperature changes on another Patrol. Perhaps I can get feedback here as to how rapidly the temperature should change. With mine, if you traveled at a constant speed, say about 80, and then suddenly accelerated, the temp used to move up at an alarming rate until it reached the high 400 c and then would slow down and slowly creep up to the mid 500c. Would that be normal?
Re: EGT
Post by Tinus lotz » 09 Apr 2017 20:35
Yip very normal all to do with the amount of right foot and uphill infront of the car ... :salute:
Re: EGT
Post by Michael » 10 Apr 2017 05:41
Sounds like a faulty probe or something related to a wrong reading. If those temps ypu are getting were correct your Patrol would be very very slow and I dont even think it would get to 120km/h.
EGT's fluctuate quite a bit and responds to the amount of fuel you give the engine. Coasting at 120km/h you can expect to see 370 to 450 degrees or more depending and the gradiant of the road.
