Terrain Tamer Suspensions
DawidT
Full Name: Dawid Taljaard
Nickname: Dawid
Home Town: Witbank
Current 4x4: 1995 Nissan Patrol GQ 4.2l Petrol and 2010 Nissan Patrol 4800.
2018 Nissan Navara
Has thanked: 1 time
Been thanked: 17 times
Re: Terrain Tamer Suspensions
Post by DawidT » 28 Sep 2017 07:02
Thanks Marinus :thumbup: , kan nie wag om dit in te sit en die verskil te voel nie :blonde:
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 16 times
Been thanked: 81 times
Post by Marino4x4 » 29 Sep 2017 08:57
DawidT wrote:Thanks Marinus :thumbup: , kan nie wag om dit in te sit en die verskil te voel nie :blonde:
Hi Dawid
Parte is gister gestuur.
Ek het vergeet om te noem. Die parte is nie mee die geel polyurethane buste nie, dit is nou die Terrain Tamer Pro Bush Synthetic Rubber Bushes wat baie beter as enige bush daar buite is.
Julle kan die resultare van die toetse sien.
Beste polyurethane bush kon 1 074 100 (78 ure) cycles doen tweede was n rubber bush en die Terrain Tamer Pro Bush kon 2 545 620 cycles (186 ure) doen.
:thumbup:
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 » 29 Sep 2017 09:21
Hier is ook n foto wat Michael vir my gestuur het. Regs is Nissan se idee van n standaard shock. Links is Terran Tamer se idee van n standaard shock.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Has thanked: 265 times
Been thanked: 261 times
Post by ricster » 29 Sep 2017 11:50
Now that look the part.... very lekker Marinus
Has thanked: 113 times
Been thanked: 93 times
Post by hugejp » 29 Sep 2017 16:02
Looking good hey!!!
:thumbup:
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 » 12 Jan 2018 15:34
Hi
I did my suspension bushes last week (Rear Trailing Arms top and bottom) with the Terrain Tamer pro bush kit (TSBK0030). Here are some photos
The kit contains all the bushes needed, clam shell design with pins. The bush grease is supplied in the kit.
There are special grooves moulded in the bush to retain the grease when the pin is inserted.
The bush is greased and the pin is inserted
These bushes has a lifetime warranty. For as long as you live or the vehicle is in your possession.
We have kits for the front and back panhardrod's as well.
We can also source the leading arm to body kits and caster correction kits (Up to 50 mm lift)
Marinus
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Home Town: Sabie
Current 4x4: none
Has thanked: 87 times
Been thanked: 118 times
Post by SJC » 14 Mar 2018 08:06
Kan jy vir ons n pryslys gee op die bushkits asb.
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 » 16 Mar 2018 10:52
Good day. Here is a price list. As mentioned, there is a lifetime warranty on the pro bush kits.
TSBK0001 Bush Kit Leading Arm to Diff R1825
TSBK0002 Bush Kit Leading Arm to Chassis R625
TSBK0012 Caster Correction 25 - 50mm R2570
TSBK0031 Trailing Arms Top and Bottom R5650
D Type Stabilizing Bar Front Bush R200 for 2
D Type Stabilizing Bar Rear Bush R300 for 2
Patrol 4.5 GL 1998
Terrain 4X4 Parts
