ZD30 turbo whine
hugh
Full Name: Hugh KENNEDY
Nickname: Hugh
Current 4x4: 2007 Patrol 3.0Di
Has thanked: 16 times
ZD30 turbo whine
Post by hugh » 25 Jan 2017 21:30
Hi, my 2007 ZD30 (only 112,000km) has developed a faint whine at high revs. I want to do a major trip this year, is it worth taking a chance, or should I just change it out?
Nissan reckon about R25k for a new turbo, does anyone have any experience with options?
Has thanked: 291 times
Been thanked: 110 times
Re: ZD30 turbo whine
Post by Kagiso II » 25 Jan 2017 22:24
TURBO WORKS: Centurion
Speak to Jan Visser there
Turbo whine can be many thingz, but look for leaks in the piping first, or the I C
Has thanked: 163 times
Been thanked: 276 times
Post by Michael » 26 Jan 2017 07:52
Jip, can be many things
But if there are no leaks/hole in the pipe then have your turbo checked out. Sometimes the compressor wheel breaks off a tip or something and it throws the turbo out of balance which causes a whine.......
On the positive side, it can be reconditioned for very cheap (around 5k - 7k) depending on what turbo it is and what the damage is.
Has thanked: 565 times
Been thanked: 295 times
Post by Tinus lotz » 26 Jan 2017 12:58
I was at turbo works now a complete overhaul on your turbo would be 5400 or less there is a 30l in the parking at the moment
DaleB
Full Name: Dale Barr
Nickname: Dale
Current 4x4: 2008 Patrol 3.0Di
Has thanked: 1 time
Been thanked: 7 times
Post by DaleB » 13 Feb 2017 21:57
I lost a turbo last year in Mozambique. One of my driving worst nightmare situations. Run away engine at 70km/hr on gear down into small village... driving home at 30kh/hr... no turbo! Impeller shaft snapped in two. Assumption is a well known repair shop used Kak oil which caused sludging. Can't prove it though. Fitted a recon turbo on my return.
Play it safe, have it checked! Engine run away in no joke!
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Has thanked: 70 times
Been thanked: 93 times
Post by Wilkie » 13 Feb 2017 22:01
I have a 2nd hand turbo available ....??
hugh
Nickname: Hugh
Post by hugh » 06 Jun 2017 12:07
So after identifying the whine, the car suddenly started losing low range power. I took it to Rob Green in Randburg for a dyno check and they found that the variable nozzle was sticking. That sorted out the power, and the whine.
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
Home Town: Cape Town ,but raised in the Tanskei
Has thanked: 1 time
Been thanked: 53 times
Post by Russ Kellermann » 06 Jun 2017 21:37
Fantastic to hear you have had good news and a good result.
Flip man,.... kak like this just makes me think i should just keep my 4.2 NA engine just as it is.
When i hear things like " it can mean many things".... i get cold shivers.
Has thanked: 260 times
Been thanked: 256 times
Post by ricster » 07 Jun 2017 08:24
haha.... come on Russ.... you know you want to, and with our old school TD42"s.... those turbos last a loooooong time without any nonsense.
Post by Michael » 07 Jun 2017 08:52
I'm with Cedric.......just do it!! you know you want to :lol:
