Newby Patrol Owner - Things to look out for
DirkErasmus
Full Name: Dirk Erasmus
Nickname: Dirk
Current 4x4: 2005 Patrol 4.8 GL
Has thanked: 46 times
Re: Newby Patrol Owner - Things to look out for
Post by DirkErasmus » 16 Nov 2016 20:06
Thank you Manne
Peter, David - how would I go about having that difflock solenoid checked out?
DirkErasmus
Nickname: Dirk
Post by DirkErasmus » 16 Nov 2016 20:11
Being a previous Hilux owner, you would forgive for asking the next question:
Do Patrols get stolen often (compared to the Toyotas for instance)?
Picasso
Full Name: HS
Nickname: Picasso
Current 4x4: Nissan Patrol
T3 Syncro
Home Language: German
Has thanked: 11 times
Been thanked: 43 times
Post by Picasso » 16 Nov 2016 20:21
DirkErasmus wrote:Thank you Manne
Welcome Dirk
I think what you want to check is the diff lock function.
Put the car on loose ground engage 4L and switch the diff lock on.
The diff lock light should initially flash and when diff lock engaged it should be indicating on the dashboard.
Wind the window down ... the rear tyres should "bite" the ground when turning.
That means your diff lock is working. (+ your diff lock selonoid + all the other components in the diff lock system)
If its not doing as described above than there could be various components at fault of which the diff lock solenoid is the most common problem .
:salute:
DirkErasmus
Nickname: Dirk
Post by DirkErasmus » 16 Nov 2016 20:28
Thank you Picasso.
Home Town: Sabie
Current 4x4: none
Has thanked: 87 times
Been thanked: 118 times
Post by SJC » 16 Nov 2016 20:28
Has thanked: 163 times
Been thanked: 279 times
Post by Michael » 16 Nov 2016 20:46
DirkErasmus wrote:Being a previous Hilux owner, you would forgive for asking the next question:
Baie welkom Dirk en dis n baie mooi Patrol daai.
Ha ha, jy hoef nie oor daai probleem te worry nie...... ek dink nie eers die Patrols verskyn op die diefstal lys nie :lol:
Jy gaan jou 4.8 baie geniet en net do baie hier op die forum
DirkErasmus
Nickname: Dirk
Post by DirkErasmus » 16 Nov 2016 20:55
Almal is so nice hier. Dankie manne. Dit maak 'n groot indruk op my. Waar in vandag se wêreld lry mens nog so 'n klomp goeie manne? :thumbup: :clap:
Post by Michael » 16 Nov 2016 20:58
Jy sal nog sien Dirk.....dis n tipe persoon wat n Patrol ry.
Almal is nice mense hier en kom gerus saam as daar n event is, jy sal dit baie geniet
Has thanked: 292 times
Been thanked: 111 times
Post by Kagiso II » 16 Nov 2016 21:20
Welkom Dirk.. jy klink bekend en dalk ken 'k jou van 'n ander forum .. Maar hoe ookal. Aangename kjennismaking en WELKOM hier oppi Patrol Forum
Has thanked: 307 times
Been thanked: 379 times
Post by Peter Connan » 17 Nov 2016 05:56
Ek weet net van een gesteelde Patrol.
Soos Picasso se, toets of die diff lock.
