Measure lift height
DH70
Full Name: Donald Hastie
Nickname: Donnie
Home Town: Melkbos
Current 4x4: 2005 Patrol 4.8 GRX
Home Language: Afr, Eng
Has thanked: 12 times
Measure lift height
Post by DH70 » 22 Sep 2016 10:41
Apparently options to measure lift height is to measure 1. from the centre of the rim up to the wheel arch (flair) or 2. bottom of spring seat (front axle) to bump stop, and subtract factory height from measurement. What's the factory height for 1. and 2. ?
Or if there's another accurate method, please share (include factory height please).
Home Town: .
Current 4x4: 2000 Nissan Patrol 4500GRX
Has thanked: 87 times
Been thanked: 117 times
Re: Measure lift height
Post by SJC » 22 Sep 2016 11:39
Maybe this will help: download/file.php?id=15618
DH70
Nickname: Donnie
Home Town: Melkbos
Post by DH70 » 23 Sep 2016 12:56
According to the guideline SJC posted, I have a 2.4" (6cm) back and 1.6" (4cm) front lift. Is it possible this was a 3" (7.62) lift initially, but sagging springs have lowered it?
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Swakopmund Namibia
Current 4x4: None
Has thanked: 85 times
Been thanked: 96 times
Post by JoshJ » 23 Sep 2016 16:20
What brand suspension? I have heavy duty front and rear. Front bullbar with winch. Rear empty drawer system. In the rear it is almost 20mm higher then infront when not loaded. This is on a 2" lift. Maybe you just have heavy duty coils in the back.
According to me the correct way is toe measure from the bottom of the rim through the centre to the arch. :mytwocents:
Being alive is a Blessing!!
Joshua
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 18 times
Been thanked: 82 times
Post by David M » 23 Sep 2016 16:44
I think Josh has hit the nail on the head.
With OME you get 400 kg springs for the back which gives me 65 mm lift.
For the front the most heavy duty is 100 kg which gave me my 50 mm lift when I put them on but has sagged to 25 mm now and are about to be replaced under warranty.
The weight rating refers to the weight over and above the normal as per the manufacturer.
OME also has standard for the front and standard, 100 kg and 200 kg for the back.
If your coils are OME and they still have the stickers you can google the code to see what you have.
DH70
Nickname: Donnie
Home Town: Melkbos
Post by DH70 » 23 Sep 2016 18:53
JoshJ wrote:What brand suspension?
OME.
No idea what springs are, but they've clearly been on the vehicle for a very long time.
Bit off the topic, have to replace back shocks (one is leaking), so who do the Cpt guys use for suspension? Safari centre quoted about 2300 for new OME's (650 to fit), 4x4 Megaworld slightly more. I'm on a very tight budget, so also phoned for quotes at the "normal" places and got feedback like Monroes (heavy duty) 1100 each, etc. I know this is not ideal, but I have to consider cheaper alternatives.
JoshJ
Nickname: Joshua
Current 4x4: None
Post by JoshJ » 23 Sep 2016 22:39
Rudgar is running with pro-fender shocks from LA Sport. He is very pleased. Its on a Hilux though. But from what I read and taking his comments in mind i recon they should be worth a look. And for those of us who know him. Knows how he drives that hilux :lol:
Safe money would be OME :mytwocents:
Joshua
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Has thanked: 70 times
Post by Wilkie » 24 Sep 2016 07:59
Donald i'll give you Rob's cell no and ask him to get you a quote from his coil spring contact and also tell him excatly what you need .if you got bullbar or tow boat..i think its iron man
0seven nine5zero2...5six2six :salute: :salute:
Tell him your part of the Nissan Forum
Picasso
Full Name: HS
Nickname: Picasso
Current 4x4: Nissan Patrol
T3 Syncro
Home Language: German
Has thanked: 11 times
Been thanked: 43 times
Post by Picasso » 24 Sep 2016 12:40
OME.
Hi Donald
If your budget is currently very tight why don't you look out for a set of original / used set of Nissan springs & shocks. Many forum members have replaced the original suspension with an aftermarket setup and might have the original parts still laying around. They have been trading on the forum for ~ 1000-2000 R.
I do have a sett but due to the distance and potential transport cost this will be of no use for you. If you think this is an option for you then check out with the CPT forum members.
:salute:
Has thanked: 554 times
Been thanked: 286 times
Post by Tinus lotz » 25 Sep 2016 08:05
G man also most times have some smaller lift shocks and coils avaliable
