Ball joints replace or service?
DH70
Full Name: Donald Hastie
Nickname: Donnie
Home Town: Melkbos
Current 4x4: 2005 Patrol 4.8 GRX
Home Language: Afr, Eng
Has thanked: 14 times
Post by DH70 » 22 Sep 2016 00:28
I had significant play on my steering, so got feedback from various people who checked the vehicle. Most obvious fix was to fasten the drag link/tie rod link which was loose and grease ball joints. It helped a lot, but still not 100%.
Ball joint boots all in good condition, however tie rod moves easily when turning it like a bike throttle, so not much resistance (no other directional movement).
Initially I was told to replace the drag link. However, after the adjustment mentioned above, another mechanic suggested I have the ball joints serviced. (Mr Ball Joint in Cpt quoted 650 to do 4 which is reasonable, although not sure it's a reliable option.). And after a quick peek this morning, our friends at Nissan say there's absolutely nothing wrong.
What to do?
If I replace the tie rod ends, any recommendations where to purchase?
And if I replace perhaps a good option is to get 4 new tie rod ends and fit a drag link like the one Peter is advertising.
Has thanked: 300 times
Been thanked: 369 times
Re: Ball joints replace or service?
Post by Peter Connan » 22 Sep 2016 05:55
Ball joints cannot be "serviced" other than just pumping in grease.
Some people "re-manufacture" them, by pumping a lot of polyurethane in and baking in an oven.
It works for some apllications, but not all. I initially had this done to mine just befora a trip to Bots in 2012. By the time we got back (3500km) they were worse than ever.
The tie rods are available from Partquip, the trick is just to find someone who knows what they are.
DH70
Nickname: Donnie
Home Town: Melkbos
Post by DH70 » 22 Sep 2016 08:25
Thanks for that Peter. Apparently they pump teflon into them, but as I suspected, probably not the best option for a heavy vehicle like ours. Will you be manufacturing more of those draglines or is this a once off? I see another batch will be done again :thumbup:
Dustin
Full Name: Dustin Roberts
Nickname: Dustin
Home Town: Port Elizabeth
Current 4x4: Patrol-less :-(
Has thanked: 43 times
Been thanked: 61 times
Post by Dustin » 22 Sep 2016 09:13
Hey Donnie
If you're struggling to find bits and pieces, drop Marinus (Marino4x4) an email on sales@terrainparts.co.za
He imports Terrain Tamer parts from Oz.
See what the pricing compares to local parts.
a.k.a. Datsun Dustin
GO PATROL !!!
Home Town: Sabie
Current 4x4: none
Has thanked: 87 times
Been thanked: 118 times
Post by SJC » 09 Apr 2017 21:25
DH70 wrote:..... however tie rod moves easily when turning it like a bike throttle, so not much resistance (no other directional movement).
Where did you get yours?
davidvdm
Full Name: David vd Merwe
Nickname: David - Hillbilly
Home Town: Carletonville
Been thanked: 15 times
Post by davidvdm » 10 Apr 2017 10:03
From 88 onward, Partquip has a ball joint TR05680. Autozonr Stock number POA.TR05680...... But I don't trust Partquip further than I can throw it... Checked with Fredrick at Interspares, but Teknorot does not make anything for the Patrols, absolutely nothing.
I was hoping to do tie rod and draglink over on the Sani that runs the 1980-83 Safari front axle. It seems I am also in a hardplace to find them. No one even has them listed anymore.
I was willing to drop back to the TR05680 ball joint, but it does not fit. It will fit the pitman and taper, but the standard tie rod tube has a M25 bolt size, and the ball joint above has a M21 bolt.
By the way, when I went looking for the ball joint, I just wanted something big and overkill. I browsed the Partquip book and found this ball joint with M21 bolt and said "thats what I want". Had the stock brought in, and only after it arrived, I asked the guys from what car it was. I was pleased to hear it was for the Patrol from 88 onward. The Cruiser only uses a M18. So we see again why the Patrols hold up so much better.
I am now speaking to the guys from Arora Heim joints to see what I can replace everything with, and what the cost will be. He tells me that M21 is already overkill, and M25 is just plane ridiculous. I want to try and get to the situation where I use the same ball joints or Heim joints for both the Tierod and Draglink to ease the amount of spares to carry. I like the "one spare fits all" situation :mytwocents: . I need to build a new draglink and steering pitmans on both ends, either way, so thats cool, I was just not bargaining on having to build a new Tierod as well.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
DH70
Nickname: Donnie
Home Town: Melkbos
Post by DH70 » 14 Apr 2017 17:33
Last year when I had this issue, I got a set of TR05677 ball joints, but never used them (still boxed in my garage). It's a Partquip box and I think I got it from Diesel-electric. I decided to leave the tie rod as is, because I was told the ball joints are ok if they don't have much resistance (as described in my original post, the "bike throttle" motion), but not ok if there's up and down movement (usually makes a clanking sound). Hope this makes sense:) Had my wheel alignment done December and the guy there agreed.
Anyway, I decided to change only the removable ball joint on the drag link as it was a bit loose (got a used ball joint from Peter C). The fixed side ball joint was ok at the time, but I noticed a month ago my steering was drifting a bit and discovered the fixed side ball joint is loose. Might wait until I get my hands on an adjustable drag link and then fit the two new TR05677's. As per David's post, I just hope the bolt size is ok with these.
