Hi All,
I need some assistance please. My headlights on the GQ just stopped working. I tested it to the best of my miner ability last night but can not sort it out.
When I switch the lights on, only the park lights front and tail lights come on (1st notch on the light switch) The second notch - main beam, dim and bright does not work. I managed to remove the switch assembly and opened it up, cleaning the contactors, but no luck - all seems fine and test through to the connector block?? not too sure about my skills.... If I bridge the contacts on the switch, the lights, dim and bright comes on! This made me think that it is not a wiring issue or relay? Could it be a bum switch?
I can get a switch from a 4.5 GU, is it similar to the GQ?
GQ headlights dead!
- DawidT
- Full Name: Dawid Taljaard
- Nickname: Dawid
- Home Town: Witbank
Nissan Patrol 4.2l GQ
Volkswagen Caravelle 4 Motion
- Has thanked: 5 times
- Been thanked: 30 times
- Has thanked: 800 times
- Been thanked: 549 times
Re: GQ headlights dead!
Jip klink soos die switch ...praat ma met dawid ....ek dink ook die 4.5 skakelaar kan werk
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 442 times
- Been thanked: 670 times
What Tinus said.
If the lights are coming on when your bridge the switch contacts, then everything harness / fuse etc-wise is working perfectly. Not sure whether a 4.5 switch will work, so try it (and let us know), or ping Dawid and get a spare from him. :)
ORRA: H80
ORRA: H80
