Rebuild of my ZD30 DDTI
PaulvdMerwe
Full Name: Paul van der Merwe
Nickname: Paul
Home Town: Graaff Reinet
Current 4x4: 2001 Patrol 3.0 DI GRX
Been thanked: 6 times
Post by PaulvdMerwe » 11 Aug 2016 12:53
Hi all,
So the time has finally arrived that I start the rebuild of my 2001 Wagon's engine,
for these of you that don't know, I bought this Partol after it suffered a injector failure on no 1 cylinder.
After replacing all the injectors and 4 new pistons i made the mistake of fitting a pirate head gasket.
I struggled from the very first day to get my EGT's down, even after fitting a 3" exhaust from turbo to tail, i still strugelled with high EGT's
Within a 1000 km after the repair the turbo blew and I replaced it with a new one.
within one week after replacing the turbo, the engine let go on me, no indication of overheating what so ever, although i did notice that it pushed the water out from the heather tank.
Opened it up again, and this time the damage was severe. 3 cracked sleeves and seize marks right through. the cause (in my opinion) - a pirate head gasket.
So after standing a few months, it is finally time that I rebuild it.
So a few questions in order that I do it right this time round.
1. I am getting the head gasket from Nissan, but there is 2 sizes 0.7 mm and 0.65 mm, seeing that I am skimming the head I would recon that I should use the 0.7mm?
2. When I did the engine the previous time (about 1000km ago) I replaced all the head bolts, must I replace them again, or will they still be fine?
I would like some input on the above, and will keep you all updated as the build goes on.
Currently the head is going for crack /pressure test and skim
Block is in to have new sleeves fitted
Crank is in to have checked
Ordering parts
Has thanked: 565 times
Been thanked: 295 times
Re: Rebuild of my ZD30 DDTI
Post by Tinus lotz » 11 Aug 2016 13:00
Mooi man lets hope you win this time :thumbup: have you got the manual ?? Isn't there a size to measure head bolts to see if they are ok or not? :think:
PaulvdMerwe
Nickname: Paul
Post by PaulvdMerwe » 11 Aug 2016 13:43
Tinus lotz wrote:Mooi man lets hope you win this time :thumbup: have you got the manual ?? Isn't there a size to measure head bolts to see if they are ok or not? :think:
Tinus,
Myne is die Auto.
Ek sien in die workshop manual is daar specs vir die head boude.
Ek sal dit meet en check.
Has thanked: 163 times
Been thanked: 276 times
Post by Michael » 11 Aug 2016 14:04
The head bolts are stretch bolts and are not re usable
I would just use the thicker gasket, as you mentioned you are skimming the head. It is such a small difference in thickness anyway that I dont see it having a real impact on anything
PaulvdMerwe
Nickname: Paul
Post by PaulvdMerwe » 11 Aug 2016 14:31
Tinus,
According to the workshop manual, the head bolts should not have a thickness variance of more that 0.15mm across the threads between D1(Diameter over the threads 10 mm from the end of the bolt) and D2 (Diameter over the threads 10 mm from where the threads end)
I checked all my bolts and the worst one is 0.14 mm, the rest are all 0.07 -0.09
Post by Tinus lotz » 11 Aug 2016 14:52
Mooi maar hoeveel kos dit om ander te kry? Wil nie al daai moeite doen en dan werk hulle nie reg nie :thumbdown:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Has thanked: 70 times
Been thanked: 93 times
Post by Wilkie » 11 Aug 2016 16:13
For what its worth specially on high compression engines with stretch bolts if you have re used the bolts once before I would advice you to replace the bolts next time round cause you are going to blow head gasket or over heating
and don't buy them from a bolt & nut shop its not the same :mytwocents: :mytwocents:
Home Town: Brits
Nissan Patrol 4.8 GRX
Has thanked: 177 times
Been thanked: 224 times
Post by iandvl » 11 Aug 2016 19:14
Personally, I would replace the stretch bolts. That is my understanding of them in any case - use once, even if they are within specification.
I would be very disappointed in myself, if I were redoing a motor, if I decided to skimp on something only to have it bite me later.
PaulvdMerwe
Nickname: Paul
Post by PaulvdMerwe » 12 Aug 2016 07:25
Morning guys,
Yes, I have also decided that new bolts it will be.
Heard from the engineers that the crank is fine and no machining necessary, so that stays standard.
Will then order the parts today. :woo:
Wilkie
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie » 12 Aug 2016 08:02
Wish you all good fortune... :salute: :salute:
