GQ 4.2 Diesel for sale - OLX
Dustin
Full Name: Dustin Roberts
Nickname: Dustin
Home Town: Port Elizabeth
Current 4x4: Patrol-less :-(
Has thanked: 43 times
Been thanked: 61 times
Post by Dustin » 10 Aug 2016 17:55
a.k.a. Datsun Dustin
GO PATROL !!!
Home Town: Sabie
Current 4x4: none
Has thanked: 87 times
Been thanked: 117 times
Re: GQ 4.2 Diesel for sale - OLX
Post by SJC » 10 Aug 2016 18:19
Wonder if the mileage is genuine? :think:
Has thanked: 255 times
Been thanked: 255 times
Post by ricster » 11 Aug 2016 09:09
Hmmmmm.... Interesting....... I may be mistaken, but the GQ patrol TD42 motor was a silver top, as they were not imported by Nissan SA. Apparently there were a few TD42 GQ Patrols brought in by an independent dealer.
Looking at this motor, it looks like a black top TD42. The quickest and easiest way to diagnose if it is a silver or black top is to check the back of the alternator if it has the vacuum pump on it.
Something is bugging me though.... there is no decal saying if it is a ST or SGL-D on the rear or on the rear side panels below the rear side window, so possibly been resprayed. Also for what its worth the oil filler cap on the tappet cover is not the right one for the TD42.
Other than that it looks in pretty decent condition other than the brake peddle rubber..... which I think shoudn't be worn out like that after only 150 000Km
Has thanked: 163 times
Been thanked: 275 times
Post by Michael » 11 Aug 2016 11:00
ricster wrote:it looks like a black top TD42. The quickest and easiest way to diagnose if it is a silver or black top is to check the back of the alternator if it has the vacuum pump on it.
The real silver top engine only ran from 1989 - 1992 I think and interestingly enough not all of them actually had silver rocker covers.
The vacuum pump did run from the alternator yes but so did some of the N/A TD42 black tops....so its impossible to tell without stripping the engine and checking the gudgeon pin sizes, piston shape and weight, precombustion chamber hole size.
Interesting fact is that the later GU factory turbo'd black top engines are stronger than the silver top motors......so if you can find one of those you are good to go :thumbup:
Post by ricster » 11 Aug 2016 15:13
" The real silver top engine only ran from 1989 - 1992 "...... nope... Grants Patrol, now Dirks Patrol is a 96 Patrol silver top. Here in SA we only got the black tops from 1998 in the GU Patrol. Stefaansie's GQ also has a silver top if I'm not mistaken. You are correct that the silver top did not always have a silver rocker cover, but from all the times I've seen a GQ TD42 it will have the vacuum pump on the alternator.
I think you got this info from the Aussie sites, as they got a few versions of the TD42, where as we seemed to get a bit of a mishmash of TD42 engines in the GU models up till the end of 1999 when we officially switched over to the ZD30. I believe Nissan put what ever stock they had together to make up the batch of Patrols that came to SA. I would actually not be surprised if there was only one shipment made to SA from Nissan which was enough to fulfill the orders till end 1999 when the ZD30 came into effect.
Post by Michael » 11 Aug 2016 20:03
Im doubting very strongly that Dirks GQ has a silvertop engine, but who really knows
jan.dup
Full Name: Jannie Du Plessis
Nickname: Jannie
Home Town: Hermanus
Current 4x4: Patrol 4.8 GRX
Been thanked: 8 times
Post by jan.dup » 12 Aug 2016 16:00
What is the 4.2's fuel consumption like ?
Has thanked: 564 times
Been thanked: 294 times
Post by Tinus lotz » 12 Aug 2016 18:37
I get a steady 8km per liter for the last 5000 km a bit more or a bit less but 8 average
Post by Michael » 13 Aug 2016 07:35
Im on 7 - 7.5km/l
Has thanked: 110 times
Been thanked: 103 times
Post by offroadbiker » 15 Aug 2016 12:09
Fully kitted with 33" tekies my average is 6.9km/l
