4.2 Turbo or not ???
Dustin
Full Name: Dustin Roberts
Nickname: Dustin
Home Town: Port Elizabeth
Current 4x4: Patrol-less :-(
Has thanked: 43 times
Been thanked: 61 times
Post by Dustin » 14 Jul 2016 15:22
HI guys
I'm in the market for a 4.2 Turbo diesel troll.
Found one, but not sure if it is a factory turbo model.
The intercooler is a top mount unit.
The guy says it's a 2000 model.
Does anyone know if this is factory or aftermarket ?
a.k.a. Datsun Dustin
GO PATROL !!!
Has thanked: 260 times
Been thanked: 256 times
Re: 4.2 Turbo or not ???
Post by ricster » 14 Jul 2016 16:14
As far as I know, and I'm pretty damn sure about this, but the station wagon NEVER came out to SA in a 4.2 with Nissan factory turbo only a N/A TD42 ( TD42 ). Only the Pick Up came out with a factory fitted turbo ( TD42Ti). They stopped producing/supplying South Africa the TD42 stationwagon end of 1999. So it may be that that one is a 1998 or 1999, but only registered in 2000. Prior to 1998 was only the GQ model with a TD42 motor (TD42).
That will definitively be an aftermarket turbo and Intercooler.
Take a pic of the Injector pump too if possible. That will also ensure the pump has the compensator on to deliver the correct fuel for the turbo's demands.
Does it have an EGT gauge fitted? I would be cautious if one is NOT fitted. The aftermarket turbos do push high EGT's and that can cause issues even to the legendary bullet proof TD42 motor.
Post by ricster » 14 Jul 2016 16:18
Looks like a decent size intercooler.... can't see much of the turbo itself though.
Looking at the photo, on the radiator hose there looks like a sensor fitted to the pipe, so good chance there is a "madman" or similar unit fitted.
Has thanked: 565 times
Been thanked: 295 times
Post by Tinus lotz » 14 Jul 2016 16:48
Looks like aftermarket cooler.... :mytwocents:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Has thanked: 70 times
Been thanked: 93 times
Post by Wilkie » 14 Jul 2016 18:20
i agree Tinus but look on the intercooler inlet and outlet and see if there is any welding on and look how it was done
Has thanked: 163 times
Been thanked: 276 times
Post by Michael » 14 Jul 2016 19:15
Def not a factory setup
The thin pipe on the thermostat housing is leading to the turbo for cooling. This means its not a Nissan turbo to start with as they are not water cooled.
Intercooler is also not a TD42 cooler like on the pickups.
Can be a nice buy if all is well on it.
As Cedric said, take a pic of the diesel pump as it will give an indication on the tipe of conversion done
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Been thanked: 74 times
Post by ChristoSlang » 14 Jul 2016 21:38
Same intercooler that I have, and my car also (originally) had a water-cooled turbo.
My guess is that you're looking at an Alpine turbo kit...
Christo (the snake man)
Dustin
Nickname: Dustin
Post by Dustin » 15 Jul 2016 09:46
Thanks for the help gents.
If I do take it, I would probable change it to a larger front mount intercooler setup.
The guy is in CT, so I'm still waiting for more info and pics.
I'll ask for pics of the pump and injectors.
I only have these pics so far (not sure why they are so small when posting here)
http://img.classistatic.com/crop/50x50/ ... 8800005007
I did stumble onto a very neat 2001 GU 4.5L if anyone knows of someone in the market for a gas guzzler :lol:
Luca - 082 604 4515
http://www.gumtree.co.za/a-cars-bakkies ... 0146969409
I'll put it on the Vehicles For Sale board as well.
GO PATROL !!!
Post by ricster » 15 Jul 2016 10:09
Dustin, Maybe you can get hold of Frans ( tour de Frans on the forum), He is the TD42 guru in the Cape in my opinion, and he has worked on my Patrol. maybe you can make an arrangement with him to have a look at the Patrol.
As for the top mount IC, I wouldn't stress too much about spending unnecessary money for a system that does work..... he will be able to service and set it up properly for you.
Tell him Cedric told you to get hold of him. He is a really lekker genuine straight up guy !!
Frans - zero eight 3 four zero nine twenty-five zero 9
Dustin
Nickname: Dustin
Post by Dustin » 15 Jul 2016 10:25
Thanks Cedric
I'll do so.
GO PATROL !!!
