Tow Bar Problem
ra_01
Full Name: Rahul
Nickname: ra_01
Current 4x4: Patrol 4.8 2016
Tow Bar Problem
Post by ra_01 » 05 May 2016 17:46
Hi Gents,
I have a problem. Wanted to purchase a Venter voyager trailer. But looks like it's not compatible with the factory fitter two bar that comes Standard.
Been to supa quick, and thy have never seen a tow bar of that nature before. Has anyone been through this problem before.
Any suggestions please...
Been thanked: 369 times
Re: Tow Bar Problem
Post by Peter Connan » 05 May 2016 18:19
In what way is it not compatable?
Has thanked: 564 times
Been thanked: 295 times
Re: Tow Bar Problem
Post by Tinus lotz » 05 May 2016 21:02
Please post a pic of the place where you want to attach the trailer then we can see :think:
ra_01
Full Name: Rahul
Nickname: ra_01
Re: Tow Bar Problem
Post by ra_01 » 05 May 2016 21:47
Hi
My patrol has a standard hook. But when I was about to take the delivery of the trailer today they said their mechanism is not compatible with Nissan standard hook. So had to return back without the trailer
Home Town: Sabie
Current 4x4: none
Has thanked: 87 times
Been thanked: 118 times
Re: Tow Bar Problem
Post by SJC » 05 May 2016 22:08
Is that (picture) the hook on your patrol?
Does not look like a standard hook. :think:
Re: Tow Bar Problem
Post by Tinus lotz » 06 May 2016 00:02
ra_01 wrote:Hi
That is a
Puntle hook not suited for towing the normal trailers and more or less more milatary spec .
You need to fit a towbar and normal hook first
Re: Tow Bar Problem
Post by Peter Connan » 06 May 2016 05:58
The hook on your car is a pintle hook which is not standard for road towing applications.
It is used by most militaries, and therefore the towing hitches are available, but not through normal spares shops. And they will be expensive too. Furthermore, there is a lot of play in such a connection, so it tows with a lot of klanking and banging.
Also, that position on your car is far too high for towing a small trailer like that. It would probably be dragging it's tail on the ground.
That pintle on your car is not fitted there for towing, but for recoveries.
You need to fit a proper towbar to the chassis, below the bumper. Speak to Bosal?
ra_01
Full Name: Rahul
Nickname: ra_01
Re: Tow Bar Problem
Post by ra_01 » 06 May 2016 06:26
Thanks for the suggestions gents.
Any recommendations for a normal tow bar?
Looks like Bossl has one, but not sure of its reliability, klanking and banging :surprised:
ra_01
Full Name: Rahul
Nickname: ra_01
Re: Tow Bar Problem
Post by ra_01 » 06 May 2016 06:28
SJC wrote:Is that (picture) the hook on your patrol?
Yes, apparently it's a heavy duty hook.
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 31 times
Been thanked: 28 times
Re: Tow Bar Problem
Post by Clem » 06 May 2016 06:29
The Bosal towbar is absolutely perfect for your requirements. I have one on my vehicle and it works very well – and I tow a reasonably heavy trailer.
