Servicing a GQ/Y60 TD42 - full service kit
DMH
Full Name: Tejan Pillay
Nickname: Tej
Home Town: durban
Current 4x4: 95 Patrol SGL 4.2D,
02 Hardbody 3L TD
Home Language: english
Has thanked: 15 times
Post by DMH » 30 Dec 2015 16:15
Servicing my Troll soon. Picked up most of the info below from Koos Best's post. Some of the rest from other chats on this forum.
Prices quoted are ex VAT from Gaydons
Going to get an oil analysis done on the spent oil. http://www.wearcheck.co.za cost R1600 for a 10-sample test kit, viz. R160 per analysis vs. R350 / analysis if you buy just one.
Some Q's:
1. Many have said you can get aftermarket filters for the rest, but go with the original Nissan air filter. Why is this? Seems like a fairly basic filter to make? Mine takes the oval, pan type air filter.
200x200-thumbnail-1447748683.1654606J00W nissan air filter patrol.jpg (9 KiB) Viewed 2941 times
2. Reference manual says you need 9.2l and 8l oil (without filter change)
But others on the forum said it took them just over 10l. How come?
OIL FILTER
Z153 (GUD) equivalent PH4738 (Framm) R61.95 + VAT
Z292 (GUD) PH2850 (Framm)– – R90 + VAT. (This is the longer one that many on the forum prefer using instead)
Caltex Delo 400 seems best - based on what users here and 4x4community say(R195 - 5l)
DIESEL FILTER
Koos said:Framm P4922 GUD Z188 - R121
Gaydons system: P5138 Z513 - R190 (This is what's in my GQ currently and the part no. GUD references to the Nissan part no.)
http://www.gud.co.za/index.php?option=c ... Itemid=108
Nissan PART NUMBER: 1640359E0AW
AIR FILTER
GUD 1001 Framm CA9308 – R210
TORA TA-534E R113 (Local spares shop & what's in my GQ currently)
Nissan PART NUMBER: 1654606J00W R375 + VAT McCarthy Nissan
BRAKES
FRONT PADS
Koos said: FERODO FDB 643 Gaydon’s said it’s for a Safari – R430 + VAT.
Gaydon's system says FDB1577 R560 + VAT
REAR PADS FERODO FDB 937 Gaydon's didn't have anything for rear
GEARBOX OIL: CASTROL VMX 80 MANUAL 4 LT (Amsoil 75W90 – Jules) 75W90 Castrol – pint 500ml– R45.98
TRANFER BOX OIL: CASTROL VMX MANUAL 1.5 LT
REAR DIFF CASTROL LSX 90 2 LT (limited slip oil) Castrol LSX90 – 5l – R245
FRONT DIFF CASTROL EPX 80/90 HYPOID 5.4 LT EP80W90 – R175 – 5l
Diff – API-GL5*1 3l - from GQ reference manual
Cooling system – 15l
Has thanked: 300 times
Been thanked: 369 times
Re: Servicing a GQ/Y60 TD42 - full service kit
Post by Peter Connan » 02 Jan 2016 17:55
I use pirate air filter on mine, which I believe is the same as the TD42. Part number is AG1001.
