Recovery Point Bolts
Home Town: Brits
Nissan Patrol 4.8 GRX
Nissan Hardbody 2.4 4x4 D/C
Has thanked: 163 times
Been thanked: 207 times
Post by iandvl » 13 Oct 2015 10:47
Folkses,
I am stuck with a problem.
In any case, I have never had a front recovery point on the 'trol. I can only assume the previous owner removed it for some reason.
Now, I recently installed a set of PC protection plates - bash plate, transfer case protector, diff guard and recovery points.
All installed very easily, apart from the right-hand recovery point, and the reason for this is that I cannot seem to find any bolts that fit the stock recovery point threads in the chassis. From what I've been able to ascertain, it's a 14mm bolt. But I've tried all thread pitches and have not been able to get a bolt to fit... :redface:
Most people I've spoken to used their stock recovery point bolts. I, unfortunately, don't have that luxury as I don't have them...
Does anybody know what the bolt specifications are ? (ie: Bolt size and thread-pitch)
Alternatively, does anybody have a set of three unused recovery point bolts lying around ?
Has thanked: 564 times
Been thanked: 294 times
Re: Recovery Point Bolts
Post by Tinus lotz » 13 Oct 2015 13:13
Take a trip to dawid you will get it by him :thumbup:
Home Town: Brits
Post by iandvl » 13 Oct 2015 13:32
Tinus lotz wrote:Take a trip to dawid you will get it by him :thumbup:
Tinus,
I'd love to. But I have no time to do so.
Busy week. Busy weekend. Heading off to Nairobi on Monday. Back shortly thereafter. Then I drive through to Bots :(
Mamba
Full Name: Anton Schutte
Nickname: Anton
Current 4x4: Patrol 4.8 GRX
Been thanked: 14 times
Post by Mamba » 14 Oct 2015 07:30
Hi Ian,
I am close to Accorn fastners maybe they can help?
Lets talk this afternoon.
Home Town: Brits
Post by iandvl » 14 Oct 2015 08:03
Mamba wrote:Hi Ian,
This afternoon ? Or tomorrow afternoon. I am very confused now.
Ian
Mamba
Nickname: Anton
Post by Mamba » 14 Oct 2015 08:09
Tomorrow afternoon...
Stefaansie
Full Name: Andre Vorster
Nickname: André
Home Town: Benoni
Has thanked: 9 times
Been thanked: 6 times
Post by Stefaansie » 14 Oct 2015 08:19
Ian,
I'm sure Peter Connan can tell you exactly what bolt it is you need.
Give him a pm?
'96 SGL-D PATROL (GQ)
ECHO 3
'07 SUZUKI BOULEVARD 1800
'06 YAMAHA 700 RAPTOR
Has thanked: 284 times
Been thanked: 365 times
Post by Peter Connan » 15 Oct 2015 07:01
They are definately M14 x 1.5, unless somebody has somehow modified it.
But if there hasn't been anything in those holes for many years, then the thread can be very dirty, preventing a bolt from going in.
You can try two things:
1) see if you can hire a tap.
2) modify a bolt into a "temporary tap". Cut a groove into a bolt with a cutting blade on an angle grinder, going against the direction of turning, if possible harden it, and use it slowly and with lots of oil.
Home Town: Brits
Post by iandvl » 15 Oct 2015 10:29
Peter,
Thanks for the info.
I'll give the cut bolt thing a try. Hopefully that will work. It's bothering me at the moment.
Ian
Home Town: Brits
Post by iandvl » 16 Oct 2015 09:29
Peter - thanks again.
The bolt thing worked a treat. Gathered the threads in the nuts must have been fairly gungded up (they really didn't look so).
In any case, cleared threads with the "cut bolt" above, and plenty of oil. And fitted my right-hand recovery point last night. Nice to have the job completed...
Ian
