Replacement studs
Has thanked: 186 times
Been thanked: 262 times
Re: Replacement studs
So dropped by at the local nuts and bolts in Krugersdorp R800 for 24 studs and nuts :surprised:
So that is Nissan R5,568 al the way to only R800 for exactly the same thing - how do they justify that???????????????
Another question - for the nut one can get the closed or open nut - which is best suited for 4x4?? was thinking the open nut will be more prone to mud getting in the nut itself??
I like the look of the open nut??
And lastly at this price I am going to fit three additional studs and nuts on the spare wheel so they are the same as the rest of the vehicle - just make more sense to me.......
Been thanked: 468 times
Did you get slightly longer studs?
I prefer closed nuts to keep mud etc off of the treads, but with open nuts you are not restricted on the stud length. With the courser thread ( Nissan stud threads are finer ) I would opt for the longer studs and open nuts, unless you can get studs 6 odd mm longer
Has thanked: 1067 times
Been thanked: 987 times
Closed nuts are probably slightly better (for the reason already mentioned), although it probably doesn't make much difference.
You want to have a minimum of 1.5 x diameter (ie 18mm) thread engagement, but these closed nuts are much longer than that, so it should not be too difficult to get a stud of such length that it will work both with and without the 6mm spacers.
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
guys I seem to remember that the Mitsubishi also used a 1.25 mm stud on the EVO models and the shank size is the same as the Nissan safari :mytwocents:
Has thanked: 189 times
Been thanked: 336 times
Yes the Dealers are really very expensive with almost everything and I dont really get why???
Had to buy a very small cover about the sise of a hand that goes on the bumper of a Parhfinder.....set me back R600......madness
Wilkie
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
It is crazy the mark up they have on the parts ,they can give you 50% discount and will still make 200% profit..and unlike the German manufacturers ,they have Goldwagen etc that sells and aftermarket product at a third of the agents price
and over the counter now..... :redface: :redface: :redface: :redface:
Return to “14. Rims & Tyres”
