Nissan OE coil spring placement need help
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Has thanked: 50 times
Been thanked: 8 times
Post by NMAD » 25 Jul 2015 11:49
Are there any good 4.8 Grx samaritans out there that can have a look at their cool spring placement for me? I need to know what coils go where by looking at the front coil which has 3 painted dots on it and let me know which side it sits on. Same for the back , please check which one has the 2 painted dots and let me know what side it sits. All 4 coils are different as they all have diff part numbers so it's a mission to fit the correct spring unless you go by the color dots. If you buy the springs new the left rear spring is r3000 but the right rear spring is r2000? And it's opposite for the front, r2000 for the left and R2400 for the right. :think:
Has thanked: 565 times
Been thanked: 295 times
Re: Nissan OE coil spring placement need help
Post by Tinus lotz » 25 Jul 2015 12:07
Longer ones on driver side i have 3 inch lift so cant check for you
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Swakopmund Namibia
Current 4x4: None
Has thanked: 85 times
Been thanked: 96 times
Post by JoshJ » 27 Jul 2015 20:34
I have a set of OE coils at home. I will check the rear ons for you. They are all the same. My front will differ thow. But I will give you there info also. Just incase. :thumbup:
Being alive is a Blessing!!
Joshua
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Has thanked: 163 times
Been thanked: 44 times
Post by Stefan » 27 Jul 2015 21:27
Fitted a set of 4.8 OE coils a couple of weeks ago. The longer coils go on the right. The larger diameter coils at the back and the smaller diameter at the front.
NMAD
Full Name: noel
Nickname: happy
Home Town: C
Current 4x4: 20
Home Language: E
Post by NMAD » 28 Jul 2015 09:09
JoshJ wrote:I have a set of OE coils at home. I will check the rear ons for you. They are all the same. My front will differ thow. But I will give you there info also. Just incase. :thumbup:
Thanks Josua, this will be great. my patrol leaned about 2 cm to the left in the front and I ended up swapping the rear coils around and now its perfectly level and looks great but I just want to make sure its right by checking with the dots on the springs to someone who know where they go as went we took them off they looked exactly the same except for the dots.
JoshJ
Nickname: Joshua
Current 4x4: None
Post by JoshJ » 31 Jul 2015 15:35
Sorry for the late reply. The one with the purple dot comes on driverside. These are both rear coils :salute:
Joshua
Home Town: Sabie
Current 4x4: none
Has thanked: 87 times
Been thanked: 118 times
Post by SJC » 31 Aug 2015 10:52
Is the front and rear coils the same length?
Post by Tinus lotz » 31 Aug 2015 12:15
No not really their springs are also different
