Battery went flat, now left side doors not opening
dieselfan
Full Name: Roy Markham
Nickname: Roy
Post by dieselfan » 11 Jul 2015 14:31
I stupidly left the interior lights on...for a week or so.
Since then I fully charged my battery and all is well except I noticed when it was flat the I couldn't open the front left. With the battery fully charged I noticed it's actually both the front left and back left doors. The central locking works fine on the right side but makes no dif on the left.
I rather strongly managed to open both left doors today using the key and one hand inside on the silver lock, there's a big amount of resistance. But it worked. Now with both doors open how do I fix? I removed battery for about 60 mins and reconnected. Nothing.
I can feel resistance on both silver locks that return them to the locked position. To open I held them "unlocked" enough to use the handle.
Please help
Has thanked: 564 times
Been thanked: 295 times
Re: Battery went flat, now left side doors not opening
Post by Tinus lotz » 11 Jul 2015 16:06
Go see graham ....programming
Has thanked: 70 times
Been thanked: 98 times
Post by Herrie » 11 Jul 2015 17:39
You can follow the door lock procedure in the manual to get it fixed.
Post by Tinus lotz » 11 Jul 2015 17:51
Those motors can take strain when trying to opperate at low voltage
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Been thanked: 93 times
Post by Wilkie » 11 Jul 2015 20:24
try locking and unlocking manualy with key,but also keep holding key in lock position for about 5sec and then also in unlocking position,maybe it will reset it self
worked on my bmw :salute:
dieselfan
Nickname: Roy
Post by dieselfan » 12 Jul 2015 10:48
Tinus lotz wrote:Go see graham ....programming
Surely if it were programming then with the battery disconnected ie no power, they should unlock?
With no battery they are still stuck shut and takes excessive force to hold in unlocked position to be able to use the door handle. They are basically jammed in the locked position?
Herrie wrote:You can follow the door lock procedure in the manual to get it fixed.
I don't have a manual :redface:
Gonna try your suggestion aswell Wilkie
dieselfan
Nickname: Roy
Post by dieselfan » 12 Jul 2015 10:52
K tried the key hold thing. Nothing.
The left side doors silver knob doesn't even make the slightest movement when using central locking. It's like they stuck half open / half closed. It's like I need a surge of sorts to reset them. Fuse?
Post by Tinus lotz » 12 Jul 2015 10:55
Low voltage makes motors brake ......about 200 buks from the patrol guynie just check it anyway :mytwocents:
Wilkie
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie » 12 Jul 2015 12:13
don't try and force the locks open and close,its definitely a safety thing that has kicked in when battery went dead,rather take it in and have the computer reset,but is not the locks . :mytwocents:
dieselfan
Nickname: Roy
Post by dieselfan » 12 Jul 2015 12:29
Wilkie wrote:don't try and force the locks open and close,its definitely a safety thing that has kicked in when battery went dead,rather take it in and have the computer reset,but is not the locks . :mytwocents:
But only the left side?
