Power 12V vs 220V
Has thanked: 103 times
Been thanked: 93 times
Power 12V vs 220V
Post by offroadbiker » 25 Jun 2015 12:57
Another fridge question - because I was wondering.............
What is the difference in power usage for a 12V fridge on your dual battery system as opposed to a 220V fridge with an inverter on your dual battery system?
Tx
Has thanked: 541 times
Been thanked: 280 times
Re: Power 12V vs 220V
Post by Tinus lotz » 25 Jun 2015 14:04
Dirk wanneer jy n battery laai gaan 45%van die energie verlore aan hitte copper losses ect ...wanneer jy 12 na 220 verander omtrent dieselde. ...maw effective use of energy. ...maak dit sin?
Post by offroadbiker » 25 Jun 2015 14:09
Clear as mud QQQ
Ja ok - ek ky die idee, maar mens moet vra anders sal jy nooit weet nie .....
Post by Tinus lotz » 25 Jun 2015 14:22
Daar is nog baie ander dinge ook stadig opstart om mider krag te gebruik ....half spoed ens alle kompressors
kan nie rond ry wanneer hulle werk nie
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 56 times
Post by Chris Skinner » 25 Jun 2015 15:14
Agree with Tinus - an inverter has quite big losses (heat, the fan for cooling etc), and the 220v fridges are not optimised for low power as the dedicated fridges.
I can do a test on my Snowman unit this weekend - ie run it on 12v and check the current/pwer consumption, and also then run it through the inverter and check... will be an interesting exercise!
