Buffalo Gorge 13-16 Junie 2015
Nickname: Witblits
Has thanked: 41 times
Been thanked: 134 times
Re: Buffalo Gorge 13-16 Junie 2015
Post by Alex Roux » 19 Jun 2015 09:49
Hi Cedric
I think the story goes like this:
Petrol fumes is cleaner when compared to old school smokeys, like your 4.2s.
But to the extent that we use more petrol than you use diesel, it may work out to be worse overall.
Modern super lean dry diesel engines are much more efficient, hence more environmentally friendly, but the gasses coming out is also cleaner.
Although both modern engines use them catalytic converters etc. So not sure on cleanliness, but definitely more efficient. Hence more environmentally friendly.
Skilpad & Shortie
Has thanked: 277 times
Been thanked: 350 times
Post by Peter Connan » 19 Jun 2015 14:07
Cedric, there are lots of theories about this.
Modern Diesel engines produce less "greenhouse gasses" (Carbon Monoxide and Carbon Dioxide) than petrol engines, but I read somewhere that they produce small amounts of a number of other gasses that are more toxic, which petrols do not do.
However, one thing is certain (and seldom considered): No matter how big, old tech and inefficient your engine is, you have to drive a hell of a long way to damage the environment to the same extent that the manufacturing process for even the smallest and most efficient econobox does.
Has thanked: 240 times
Been thanked: 247 times
Post by ricster » 19 Jun 2015 14:25
HAHAHA.... yeah that's true !!
Has thanked: 160 times
Been thanked: 269 times
Post by Michael » 19 Jun 2015 14:34
+1 Piet
And not even mentioning an erupting volcano!!
Home Town: .
Current 4x4: 2000 Nissan Patrol 4500GRX
Has thanked: 87 times
Been thanked: 117 times
Post by SJC » 11 Oct 2015 10:22
Hoeveel tyd het mens nodig om Buffalo Gorge te doen?
Ek oorweeg dit om daar 'n draai te maak 24-25 Oktober.
Has thanked: 107 times
Been thanked: 100 times
Post by offroadbiker » 12 Oct 2015 07:04
Scenic route so 3-4 ure en die 13 Obstacles heen en weer oor die "stroompie" seker so 2 ure as jy 2-3 voertuie is.....
As dit egter gereen het kan daai "stroompie" 'n perd van 'n ander kleur word...................
