TB42 Flywheel fit TD42
NamibiaPatrol
Junior Member
Junior Member
Full Name: W
Nickname: D
Home Town: Windhoek
Current 4x4: Nissan GQ Patrol
Post by NamibiaPatrol » 02 Feb 2015 08:05
Good Morning,
Does anyone know if a TB42 flywheel will fit a TD42? The maintenance manual gives the same dimensions for both and the salesman at the spares shop says the clutch kit etc are the same for both but can one of the Patrol gurus confirm please.
Thank you very much.
Has thanked: 240 times
Been thanked: 247 times
Re: TB42 Flywheel fit TD42
Post by ricster » 02 Feb 2015 09:01
Hmmmmm.... Not sure, but will be interesting to hear the opinions !!
Has thanked: 275 times
Been thanked: 348 times
Post by Peter Connan » 02 Feb 2015 17:34
I have no idea, but I do have a TB42 flywheel here, so if you measure yours and I measure mine, we can find out.
Alternatively, you can have this one for the price of postage.
minwater
Full Name: Dawid Fourie
Nickname: Dawid Minwater
Home Town: Brackenfell
Current 4x4: 1996 Patrol sgl
Been thanked: 13 times
Post by minwater » 02 Feb 2015 19:06
Just make sure about the weight of the flywheels.They might measure the same for the clutch and the crank but could differ in weight
DEVOLSCHENK
Full Name: DAVID VOLSCHENK
Nickname: VOLLA
Home Town: WARMBATHS (BELA BELA)
Current 4x4: 3.0DTi GRX met td42ti
4.2D GQ SUV (DIE LIMMO)
4.2d GQ BAKKIE
1100 GS
Been thanked: 7 times
Post by DEVOLSCHENK » 02 Feb 2015 22:31
They doen differ in weight. The TD 42 flywheel is much heavier than the petrol one.
NamibiaPatrol
Junior Member
Junior Member
Full Name: W
Nickname: D
Home Town: Windhoek
Post by NamibiaPatrol » 04 Feb 2015 18:55
What would the weight difference be? If its the same dimensions how would they accomplish this?
Peter, I appreciate the offer but I have a TB flywheel. Thank you anyways.
minwater
Post by minwater » 04 Feb 2015 20:34
Yes the dimensions as far as the areas where the clutch,crank and ring gear fits are the same but the flywheel will be thicker
Users browsing this forum: Google [Bot] and 1 guest
