My GU 4.2 Turbo Diesel
Has thanked: 300 times
Been thanked: 371 times
Re: My GU 4.2 Turbo Diesel
Post by Peter Connan » 25 Aug 2017 05:44
Ek sal maar die agtergeblewene bly...
:biggrin:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Has thanked: 70 times
Been thanked: 93 times
Post by Wilkie » 25 Aug 2017 07:20
Jis Micheal ..dis bad news oor daai suiers van jou.... :redface: :redface:
Ek weet ons het ten duurste betaal vir wanneer ons ren motors gebou het want ons wil altyd die ligste maar sterkste pistons gehad het, want hoe ligter hoe meer H/P
voorspoed met daai herbou van jou en as jy dit kan inwerk in jou budget moet jy dit as veiligheids maat reel maar ceramic coat..... :salute: :salute:
Dustin
Full Name: Dustin Roberts
Nickname: Dustin
Home Town: Port Elizabeth
Current 4x4: Patrol-less :-(
Has thanked: 43 times
Been thanked: 61 times
Post by Dustin » 25 Aug 2017 08:21
Sorry to hear about the dramas on your troll Michael.
It just shows you how strong the TD42's are that it could take over 1 bar boost pressure for so long before this happened. At least the damaged was only on the top end and you didn't put a conrod through the block.
Just a thought, but since you've got it all apart and you're going through all the effort of balancing, etc.
Why don't you look at putting forged H-beam conrods in ? :mytwocents:
Then you know you can throw big boost at it at a later stage and it will take it like a champ :biggrin:
a.k.a. Datsun Dustin
GO PATROL !!!
Has thanked: 163 times
Been thanked: 276 times
Post by Michael » 25 Aug 2017 11:31
Errol yes I was really hoping to get stuff ceramic coated, but its just to expensive at this stage. Looking at around 3k for the piston crowns and 2.5k for the precombustion chambers.
Dustin H beams are almost 9k so its also aout of my budget.
I do however think my current ones will be able to handle the power I am aming for, they are quite strong it seems
Wilkie
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie » 25 Aug 2017 12:51
gaan jy reg wees vir Moetgatle
Post by Michael » 25 Aug 2017 17:04
Verseker!!
Get vanmiddag al my parte gekry so begin Dinsdag engine bou sodra my goed terug kom van balansering af
Rudolph
Nickname: Rudolph
Home Town: Bathurst
Current 4x4: Nissan Patrol Y60 4.2D 1991
Mazda BT50 2007 4x4
Has thanked: 54 times
Been thanked: 20 times
Post by Rudolph » 26 Aug 2017 15:27
Jammer om te hoor van die dilemma met die verkeerde pistons, wys nou maar net soos jy sê, mens moet maar net die regte parte gebruik vir die regte applikasie.
Sterkte met die herbou, hy gaan verseker sterker wees as enige ander TD42 na die episode. :woo: QQQ
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Been thanked: 74 times
Post by ChristoSlang » 26 Aug 2017 18:19
Michael wrote:... you cannot run 1 bar+ boost on N/A pistons...
Eish Michael, nou maak jy my benoud! Chuck loop presies 1 bar (met veilige EGTs), maar sy pistons is verseker ook nie van daai die super-duper turbo pistons nie.
As dinge dalk sou breek sal ek ook van daai frisser pistons insit, maar solank alles nog mooi aanhou werk ry ek hom net soos hy is...
Christo (the snake man)
Post by Michael » 26 Aug 2017 20:00
Christo, ek moet by se dat die aftermarket NA pistons verseker swakker is as die NA Nissan pistons vir wat dit werd is.
Ek het my EGT's altyd onder 600 gehou, maar selfs dit was te veel vir hulle.
Ek het dit nie in my ander posts genoem nie, maar al my pistons het begin kraak van die gudion pin af na die piston top toe......hulle kon maar net nie vat wat ek gegee het nie
Has thanked: 565 times
Been thanked: 295 times
Post by Tinus lotz » 26 Aug 2017 20:22
Chuck het n export motor was n shortie left hand drive gu miskien het hy daai dik top pistons in....imho change die pistons voor hulle breek daai ga lelik wees head en blok kos dik geld :surprised: :mytwocents:
Return to “08. Your Patrol”
