What's wrong with this picture?
Adamastor
Full Name: Hannes Baard
Nickname: Adamastor
Home Town: Hermanus
Post by Adamastor » 16 Jun 2014 16:26
Hi everyone...
Have not been active for a while, but had to share this with you.
Recently did a 2 500km "zig zag" trip between the West Coast, Upington and back - all via back and farm roads.
Found that my left rear tyre kept on loosing pressure, like less than 500mb per day - so nothing to get anxious about, but still.
I constantly checked for a leak of some sort, even putting some moisture on the valve opening - but nothing obvious.
Until at a "pit stop" about halfway between Pofadder and Niewoudville and some 90km due West of Brandvlei (as the crow flies) I decided that the tyre pressure is just not right - something did not feel right. You know, you "mos" sometimes get that feeling...
Anyway, I hauled out the compressor, connected up the air hose and pulled on the hose to get closer to the power point, when I noticed this continuous hissing.
Thinking it was the normal deflating that you get when you connect the air hose I did not take notice until I got back to the tyre and I was just about to switch on the compressor.
Low and behold, the metal insert of the valve was actually busy coming out of the rubber valve body...
As I touched it, it popped right out - imagine it happened at about 100km/h on one of those dust roads...
Thanks for that little voice inside my head...
Listen to it... you might just live to tell the tale...
DSC07004 _rev.JPG (96.25 KiB) Viewed 2987 times
DSC07005 _rev.JPG (88.62 KiB) Viewed 2987 times
DSC07013 _rev.JPG (106.81 KiB) Viewed 2987 times
DSC07010 _rev.JPG (118.47 KiB) Viewed 2987 times
DSC07011 _rev.JPG (96.78 KiB) Viewed 2987 times
2009 Nissan Patrol 4.8 GRX - soos sy van haar ma af kom...
Has thanked: 70 times
Been thanked: 98 times
Re: What's wrong with this picture?
Post by Herrie » 16 Jun 2014 18:28
How did you fix it? :think:
Has thanked: 564 times
Been thanked: 295 times
Post by Tinus lotz » 17 Jun 2014 12:19
Never seen that before? Are those the valves from nissan?
Adamastor
Nickname: Adamastor
Home Town: Hermanus
Post by Adamastor » 17 Jun 2014 20:50
Herrie wrote:How did you fix it? :think:
Hi there Herrie...
Used some glue from my "patch kit" as a temporary measure.
But I replaced that wheel with the spare just in case and had the valve replaced when I got home.
Adamastor
Nickname: Adamastor
Home Town: Hermanus
Post by Adamastor » 17 Jun 2014 20:53
Tinus lotz wrote:Never seen that before? Are those the valves from nissan?
Hi Tinus
They are standard SupaQuick issues.
Were replaced when the BF Goodriches went on.
martyn
Full Name: Charles Fry
Nickname: Charlie
Current 4x4: Patrol 4.5
Has thanked: 9 times
Post by martyn » 18 Jun 2014 21:27
Just found the same thing happened to the diesel bowser trailer on site on Monday as well.
Diem Dulcem Habes
Have a good day
AndrewA
Full Name: Andrew Anderson
Nickname: AndrewA
Home Town: Kensington, Johannesburg
Current 4x4: Patrol GRX 4.8, 2010
Patrol GL, 2014
Post by AndrewA » 24 Jun 2014 22:48
I have seen this before it happened on a cruiser, we did much the same as you. So this does not relate to only patrols. I carry spare complete valve stems just in case, I fitted a TPMS and these have alloy stems and I am worried I will break one on a trip on rock or something like that.
Current 4x4: 1998 Nissan Patrol 4500 GRX, 2011 Zook
Has thanked: 111 times
Been thanked: 90 times
Post by Jorrie » 30 Jun 2014 11:59
AndrewA wrote:I have seen this before it happened on a cruiser, we did much the same as you. So this does not relate to only patrols. I carry spare complete valve stems just in case, I fitted a TPMS and these have alloy stems and I am worried I will break one on a trip on rock or something like that.
Good point, thanks. I will start carrying spare valve stems as well since I also have those aluminium stems with the TPMS.
4500 GRX
Jimny
Adamastor
Nickname: Adamastor
Home Town: Hermanus
Post by Adamastor » 30 Jun 2014 12:35
Hey guys
Just reading the responses reminded me...
I also carry a few valve stems including valve inserts and caps as a matter of course.
Such a simple thing... but such terribly difficult job to accomplish in the middle of nowhere.
Who carries tyre levers et al, when you are this close to civilization?
So there I have all the spares, but near enough to a tyre shop to have it repaired for 50 bucks later the same day. And no stress for me.
Enjoy the ride...
tour de frans
Been thanked: 15 times
Post by tour de frans » 23 Aug 2014 14:41
Good day. I carry the normal tyre stuff to do a repair and a bead breaker. That is a very handy tool. Helped myself and allot off other people.
Aka: Ou Grootte
99' GU Patrol, LS1 V8 with std G/box custom convertion.Hydraulic radiator fan-motor.
The 4.2 Diesel Custom Turbo engine- retired
The 4.0 Falcon Engine- retired
Return to “14. Rims & Tyres”
