RaceChip® Pro2
Giladbethalevi
Full Name: Gilad Bet-Halevi
Nickname: Gil
Home Town: Bushey soon Sandton
Current 4x4: Just purchased a 4.8 Patrol GRX
Home Language: English, Hebrew
RaceChip® Pro2
Post by Giladbethalevi » 15 May 2014 14:07
Has any one purchased and installed the RaceChip® Pro2 on a 3l patrol? I was thinking of buying one to try solve my power issues. Was diving up hill a few week ago and the car was struggling I had to keep playing with the gears to get it to go as large 18 wheelers where taking me over miss my 4.8 that had real power
Any advice will help before I lay out the money is it worth it? I am looking for performance don't care about fuel eficency
I have a 2009 model
Has thanked: 570 times
Been thanked: 296 times
Re: RaceChip® Pro2
Post by Tinus lotz » 15 May 2014 17:12
When I went on the road with agarob on the way back from kasane we were cruising at 130km per hour gps had to put foot to keep up....are you sure your car is on speck before you modify it?
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Has thanked: 163 times
Been thanked: 44 times
Re: RaceChip® Pro2
Post by Stefan » 15 May 2014 18:52
You could have a MAF sensor failure
Has thanked: 307 times
Been thanked: 381 times
Re: RaceChip® Pro2
Post by Peter Connan » 16 May 2014 06:27
What you describe is a problem that needs to be fixed.
A broken system cannot be "modified right". :mytwocents:
Riaan Harding
Full Name: Riaan Harding
Nickname: Riaan Harding
Home Town: Meyerton
Current 4x4: Nissan Hardbody
Re: RaceChip® Pro2
Post by Riaan Harding » 16 May 2014 09:14
Giladbethalevi wrote:Has any one purchased and installed the RaceChip® Pro2 on a 3l patrol? I was thinking of buying one to try solve my power issues. Was diving up hill a few week ago and the car was struggling I had to keep playing with the gears to get it to go as large 18 wheelers where taking me over miss my 4.8 that had real power
I have a 2009 model
Hi
I am a supplier of Racechips, its worth it, I have a demo and you are more than welcome to test it.
This is what you can expect from the PRO2
Performance 118kW -> 155kW +31%
Performance 160PS -> 211PS +31%
Torque 380Nm -> 466Nm +23%
Riaan
Kind Regards
Riaan Harding
Rugged 4x4 Fitment centre
E-mail riaan@rugged4x4.co.za
Website www.rugged4x4.co.za
Cell nr 0766571712
tour de frans
Been thanked: 15 times
Re: RaceChip® Pro2
Post by tour de frans » 25 Jul 2014 11:14
Hello
Ek stem met die ander. Voor jy n chip van enige maak koop. Toets eers of die kar reg perform.
n Regte chip maak wel n verskil maar dit help nog altyd nie op n kar met n fout nie.
Bv. n 100kw kar kan 110 kw maak met n chip. maar as jou 100kw kar begin op 90 kw, maak n chip hom miskien 100kw. Dit beteken dan niks.
Aka: Ou Grootte
99' GU Patrol, LS1 V8 with std G/box custom convertion.Hydraulic radiator fan-motor.
The 4.2 Diesel Custom Turbo engine- retired
The 4.0 Falcon Engine- retired
Has thanked: 292 times
Been thanked: 111 times
Re: RaceChip® Pro2
Post by Kagiso II » 25 Jul 2014 21:29
Heyyy there Mr Gilad ..
You good ?? Great - below translation to the Brit lingo .. Frans is right .. DO NOT INCREASE POWER WITH A FAULTY EXISTING ..
Fix the cold, not the symptoms..
MAF
Filters
Fuel pum [in main tank]
EGR
Burnt valves
dirty fuel .. and what not .. :mytwocents:
Re: RaceChip ® Pro2
Unread postby tour de france »Fri Jul 25, 2014 11:14 am
Hello
I agree with the others. Before a chip making any purchase. First test if the car performs right.
A real chip does make a difference but it still does not help on a car with a fault.
Eg. a 100kW car can make 110 hp with a chip. but if your car starts to 100kW 90 kw, making him perhaps a chip 100kW. This means nothing.
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Swakopmund Namibia
Current 4x4: None
Has thanked: 85 times
Been thanked: 96 times
Re: RaceChip® Pro2
Post by JoshJ » 24 Aug 2014 22:43
Hi Gil,
Did you chip yet? Or did you find an alternative solution. Mine is also pap. Aspesialy in 4th and 5th gear. It doesn't pull at all. I'M also looking in to the chip. The chances of something wrong on my Trol is slim as it is stil brand new. Only thing that makes sence is the turbo boost control that is described else where on the forum.
Please let me know?
Being alive is a Blessing!!
Joshua
Home Town: Sabie
Current 4x4: none
Has thanked: 87 times
Been thanked: 118 times
Re: RaceChip® Pro2
Post by SJC » 15 Jan 2015 06:19
Is it possible to install a racechip on a 4.2d patrol ?
What other "performance boosting" options do we have?
Re: RaceChip® Pro2
Post by Tinus lotz » 15 Jan 2015 07:36
SJC wrote:Is it possible to install a racechip on a 4.2d patrol ?
There is no ecu only a 12v solinoid on the pump all mecanical nothing for chip to control
