Manifold Wrap
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 19 times
Been thanked: 84 times
Re: Manifold Wrap
Post by David M » 07 Feb 2014 07:19
[/quote]I have no experience with ceramic coating, but suspect it could cause the same issues. I think David's idea of fitting the heat shield is the best if the manifold is old and you don't want to replace it.[/quote]
I agree. same effect.
My problem with the deflector is it sends the heat down which is where I have the problem. The pipe to the clutch slave cylinder went due to the heat.
Maybe the solution is to wrap the top of the manifolds and then any other components that may be affected by the heat?
Has thanked: 292 times
Been thanked: 111 times
Re: Manifold Wrap
Post by Kagiso II » 07 Feb 2014 11:18
The down pipes [branches] on the Prado is ceremic coated .. BIG BIG Major "B" difference in ander bonnet temps ..
It is die the part from 3-into 1 and 2 into 1 that I need to cover.
That r3000 for the ceramic coating is the best 3 K I have blown on the Prado [BIGGEST waste was the EFS suspension .. ]
Has thanked: 569 times
Been thanked: 295 times
Re: Manifold Wrap
Post by Tinus lotz » 07 Feb 2014 17:49
0114722681 is genet accoustic no they sell the wrapping too
David M
Home Town: Midrand
Re: Manifold Wrap
Post by David M » 09 Feb 2014 09:19
Bought 30 m roll of 50mm wide ceramic tape fromThermolag on Friday. Will fit it and coat with aluminium paint in 2 weeks time and let's see the result.
Re: Manifold Wrap
Post by Tinus lotz » 09 Feb 2014 10:50
Remember to rap the fiber with normal wire to about 15mm apart it helps to keep it together with the paint . :thumbup:
J@coBez
Full Name: Jaco Bezuidenhout
Nickname: Jaco
Home Language: Afrikans
Re: Manifold Wrap
Post by J@coBez » 12 Mar 2014 10:59
Please read Peter's post, i have removed my wrap last week due to the same problem.
The wraps work well for under bonnet temp but not for the condition of the branch. The branch was wrapped for about 8 months and has reduced the branch life by at least 50%. With all the rain and water puddle playing the branch has now also cracked.
So has anyone have a extra branch for a 4.8 Y61?
PathMaker
Full Name: Graham Cumming
Nickname: PathMaker
Home Town: Centurion/Pretoria
Has thanked: 1 time
Been thanked: 43 times
Re: Manifold Wrap
Post by PathMaker » 12 Mar 2014 12:46
Graham says he is not selling his ... sorry.
J@coBez
Nickname: Jaco
Re: Manifold Wrap
Post by J@coBez » 12 Mar 2014 14:07
His if i am not mistaken is a 4.5 that we had coated and will not fit but thanks for the reply any way.
Tell him to take the wrap off and make heat shield's
Thx
Jaco
Nickname: Witblits
Has thanked: 42 times
Been thanked: 142 times
Re: Manifold Wrap
Post by Alex Roux » 14 Apr 2014 22:31
I have spoken to a few people about this wrapping business
It seems if you drive through mud and water the wrap goes vrot quickly.
In fact, apparently in some cases, rally teams gets it replaced almost for every stage of the race.
Not worth it.
I have added a heat deflector plate on the body of my car above the silencers.
This helps with temps on the floor behind the passenger seat.
Otherwise will live with the hot pipes.
Skilpad & Shortie
