fittings and seats
biggles
Full Name: Steven
Nickname: Steve
Home Town: Durbanville
Current 4x4: GUII Patrol 4.8
Has thanked: 14 times
Been thanked: 63 times
fittings and seats
Post by biggles » 20 Jan 2014 07:41
I am trying to get some stuff that was missing off the patrol when i got it:
Sunglasses holder in the overhead console.
Cover for rear right door hinge.
Jumpseats in grey leather or grey cloth.
And plastic plugs/ switches that go left of the radio:
:layrubber:
IanT
Full Name: Ian Temperley
2003 4.2 TDI (Ubhejane)
Been thanked: 56 times
Re: fittings and seats
Post by IanT » 20 Jan 2014 08:26
Try Graham I know he has the consol with the sunglass holder. His forum name is Pathmaker, There is also a GU being stripped on Junkmail maybe give them a ring. Cheers Ian :thumbup:
Has thanked: 260 times
Been thanked: 257 times
Post by ricster » 20 Jan 2014 10:42
Biggles, I'm assuming you have the same Patrol as I have. The GU 4.2 Diesels only came out for 2 years (1998-1999). thereafter they changes to the 3.0 engine. The 4.2 diesels also only came out here in SA as the GL model, which had absolutely zero luxuries.... :lol: :lol: ... There was never a roof console fitted or sub tank or sunroof or climate control or leather seats. However the leather seats was an optional extra.
The roof console can be retrofitted. Christo who is quite an electrical boffin in my opinion did a roof console installation in his Patrol ( exactly same as mine) and with a detailed wiring diagram to get everything working. However its not a simple quick job, and a lot of cutting and behind the dashboard and instrument cluster work needs to be done. But having said that, I managed to do it, and I'm no electrical fundi.
The buttons to the left of the radio.... If you still have the original electric aerial, then the top left button adjusts the aerial to either be fully extended, or can be set at a halfway mark. Chances are that yours has already been replaced with something else, and you will never need that button again. My suggestion... just fit a blank plug in the space.
IanT
Post by IanT » 20 Jan 2014 12:14
I agree Ricster, I had a look at doing a retro fit on the roof consol on my 4.5 Graham thought that the same wireing harness was used on the GL and GRX, NOPE! I would have to pull power from the rear lights and would have to buy and fit the sensors for the temp gauge and compass so decided just to leave it as it was, bought a temp gauge from Midas and have a compass in the draw system! :mytwocents:
Post by ricster » 20 Jan 2014 12:41
The wiring was pretty easy, as long as I followed Christo's manual. The soldering onto the back of the instrument cluster was a little stressful for the compass pulse, but the worst was taking a knife to the roof lining..... measure 20 times and cut once.... no room for error. The thermistor with resistors to get the accurate temperature( again thanks to Christo ) was easily soldered together and connected in front of the radiator as is on the standard installation. It was one of the best mods I've done. I have my bluetooth mic fitted in there too with the map reading lights ( fitted with LED globes makes easy work looking into the dark cubbyhole at night.
If someone wants the roof console installation guide, give me a shout.
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser » 20 Jan 2014 13:12
Just for the record, Biggles' Patrol started life as a 3.0 GRX, but was converted to 4.2 TD (by then owner Pieter du Toit) when the original motor expired, so he would have the GRX refinements as standard equipment.
Post by ricster » 20 Jan 2014 13:35
ahhhhh.... the thick plottens...... :rolling: :rolling: :rolling: sorry mate.... my blonde hair again.... Thanks Gerrit
biggles
Full Name: Steven
Nickname: Steve
Post by biggles » 21 Jan 2014 00:12
Gerrit Loubser wrote:Just for the record, Biggles' Patrol started life as a 3.0 GRX, but was converted to 4.2 TD (by then owner Pieter du Toit) when the original motor expired, so he would have the GRX refinements as standard equipment.
Signature updated to avoid similar confusion later :eureka:
OK, indeed my aerial doesn't budge, so i will have to look into that. Plugs would be nice. Looking at holes in the dash really annoys me.
:layrubber:
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Been thanked: 74 times
Post by ChristoSlang » 21 Jan 2014 22:45
I have a set of rear jump seats (grey cloth) that I'm not using. A case of Tafel Lagers and they're yours!
PS: Maybe I should publish my roof console retrofit guide on the forum?
Christo (the snake man)
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Has thanked: 163 times
Been thanked: 44 times
Post by Stefan » 22 Jan 2014 07:33
Yes please Christo!
