Unbreakable Patrol keeps breaking
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 17 times
Been thanked: 74 times
Post by David M » 10 Jan 2014 09:39
So I have had the Patrol for just over a month and have had more issues in one month than my previous Hardbody's and Sani in 8 yrs........ :surprised: WTF?????????
Latest is it will not start this morning. All lights come on, motor turns but nothing. Take out a spark plug and no spark!!!
Any ideas??? Sensor????
My normal mechanic and Graham (Pathfinder) are closed until Monday............
1999 4,5 GL
IanT
Full Name: Ian Temperley
Current 4x4: 2001 4.5 Grx (Mean Green)
2003 4.2 TDI (Ubhejane)
Been thanked: 54 times
Re: Unbreakable Patrol keeps breaking
Post by IanT » 10 Jan 2014 11:06
Have you got Fuel? If you turn on the ignition (don't turn over the motor) you should hear the fuel pump running from the rear for a few seconds, Also may be a plan to full off the fuel pipe (yours is a 4,5 with carbs yes??) and see if it is pumping through to the carbs
IanT
Post by IanT » 10 Jan 2014 11:11
Sorry didn't read your last post thought you had spark
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 15 times
Been thanked: 68 times
Post by Marino4x4 » 10 Jan 2014 11:17
Unfortunately the Patrol can also break if it is not properly maintained and unfortunately buying a secondhand car you do not know what the previous owner did with it. You are sitting with the previous owners problems. Hope you can sort it out quickly and cheaply. :thumbup:
The 4.5 is a fuel injected engine. The 4.2 was the last carb model.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
David M
Home Town: Midrand
Post by David M » 10 Jan 2014 11:58
Thanks guys. I smell fuel after taking the sparkplug out so have checked no further on that front. The only thing that I can think of is a sensor that has gone faulty making the ECU not allow it to spark. Only problem is as much as I know the VG30 like the back of my hand I know sh&t about the RB45 and no one around to help today.
I have purposely not posted the other problems as some are caused by someone recommended on this site to the previous Owner and are just K&K workmanship (Not Graham).
The previous Owners had all the maintenance done and I have the records with invoices so not their fault. Just mechanics that do not practice preventative maintenance. I will get that sorted over the next 2 months.
Anyone with ideas on my sensor theory?
Has thanked: 70 times
Post by Herrie » 10 Jan 2014 12:36
Hi David, do you have a Patrol manual?
Has thanked: 260 times
Been thanked: 99 times
Post by Kagiso II » 10 Jan 2014 13:02
Did you check the coil ? [it's a square box halfsize to a packet 20 smokes] [on the VG 30 it was red ... ]
seker jy HET al daarna gekyk .. oompi "soundboard" net sommer .
David M
Home Town: Midrand
Post by David M » 10 Jan 2014 13:49
Herrie wrote:Hi David, do you have a Patrol manual?
Afraid not. Its on the "to do" list for next week but that's not helping me today.
David M
Home Town: Midrand
Post by David M » 10 Jan 2014 13:50
Kagiso II wrote:Did you check the coil ? [it's a square box halfsize to a packet 20 smokes] [on the VG 30 it was red ... ]
Dankie Oom maar kry hom nie..... waar sit hy?
Has thanked: 235 times
Been thanked: 322 times
Post by Peter Connan » 10 Jan 2014 14:04
AFAIK the coil on the TB45 is mounted inside the distributor, and so probably are all the other sensors that make the spark work.
Here is a link to a free down-loadable manual.
http://grosjean.pierre.free.fr/Y61%204, ... 9e-y61cg3/
I have a dizzy here, just missing the drive gear at the bottom, if you are interested?
Sorry, I don't know how else to help.
