Nissan recalls 2006-2013 ZD30 Patrols
The Good, The Bad & The Ugly
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Has thanked: 5 times
Been thanked: 71 times
Post by ChristoSlang » 01 Oct 2013 21:31
Christo (the snake man)
Nickname: Witblits
Has thanked: 41 times
Been thanked: 134 times
Re: Nissan recalls 2006-2013 ZD30 Patrols
Post by Alex Roux » 01 Oct 2013 23:13
They will recall 25,000 ZD30 Y61 units in Australia, while the report states "...there have not been any incidents reported in Australia..."!!!
Yet, regarding the overfuelling problem of these very same engines, Nissan have remained dead silent.
Skilpad & Shortie
AndrewA
Full Name: Andrew Anderson
Nickname: AndrewA
Home Town: Kensington, Johannesburg
Current 4x4: Patrol GRX 4.8, 2010
Patrol GL, 2014
Post by AndrewA » 06 Oct 2013 19:54
What is the overfueling that you are talking about? I have a 4.8 and at times I can smell petrol I have seen it also overflowing out of the two caps. Nissan has replaced the cap but it has happened again. It is not consistent so difficult to solve.
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 31 times
Been thanked: 28 times
Post by Clem » 07 Oct 2013 08:09
AndrewA wrote:What is the overfueling that you are talking about? I have a 4.8 and at times I can smell petrol I have seen it also overflowing out of the two caps. Nissan has replaced the cap but it has happened again. It is not consistent so difficult to solve.
Over fuelling refers to excessive amounts of diesel being injected into the cylinders. It has nothing to do with your 4.8 and "overfilling". I have no problems with my 4.8 fuel caps.
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 16 times
Been thanked: 72 times
Post by Marino4x4 » 07 Oct 2013 08:37
Hi Andrew
Over fueling is a term used for diesels that a running to rich. There are more diesel in the cylinder than can be burned with the O2/air that are in the cylinder. This causes high temperatures in the exhaust. This can lead to a cracked head, burned pistons.
Over fueling in petrol cars, like your 4.8, is called a to rich mixture. This can be sorted out with a decent dyno and adjustments on your car's ECU. This will improve your fuel efficiency as well. The biggest fueling problem with petrol engines is when it is running lean. This causes high temperatures in the engine. I have a 4.5 Patrol and I also smell a bit of petrol when the engine is cold. This seems to be normal for the patrols. I had my car at a dynotuner after I replaced my petrol pump.
I hope this makes it clearer to you. If someone knows more on this they can add or if I said something incorrect please feel free to correct me.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
AndrewA
Nickname: AndrewA
Patrol GL, 2014
Post by AndrewA » 07 Oct 2013 19:51
Put very clearly, thanks.
Has thanked: 282 times
Been thanked: 104 times
Post by Kagiso II » 07 Oct 2013 20:46
and here I am looking at a 2005 3.0 GRX to trade the Pratou for ??
Sal Grootseun moet nader roep om al die trix te doen om daai Patrol laaaank te laat lewe :-)
Nickname: Witblits
Post by Alex Roux » 07 Oct 2013 21:08
Dan kon Oom mos maar netsowel vir Agarob gehou het?
Skilpad & Shortie
Has thanked: 543 times
Been thanked: 280 times
Post by Tinus lotz » 07 Oct 2013 21:32
Ek se ook so ja.....
Post by Kagiso II » 07 Oct 2013 21:33
Alex Roux wrote:Dan kon Oom mos maar netsowel vir Agarob gehou het?
:redface: :rolleyes: jippp .. so sad ek het nie
Return to “17. Nissan SA, Dealers & Workshops”
