Headlight Booster Harness
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 16 times
Been thanked: 72 times
Post by Marino4x4 » 01 Oct 2013 11:04
I was looking around on the 4x4direct website and came across the Headlight Booster Harness they sell.
h4-harness copy.jpg (60.06 KiB) Viewed 1899 times
This got me thinking :think: if it is necessary to get these for my 1998 4.5 GL? Is the wiring of the car good enough or will the harness make a noticeable difference to my headlights? My car got the bulbs in that I bought it with. I am not to sure what the watts of the bulbs is. Has any one done the replacement of their lighting harness?
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Has thanked: 541 times
Been thanked: 280 times
Re: Headlight Booster Harness
Post by Tinus lotz » 01 Oct 2013 11:06
Dont they use that product when much bigger bulbs are used?
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 » 01 Oct 2013 12:03
As far as I have it, if you have a 55w, 60W, ..., 100w, 130w bulb and you wires is old or to thin, they will not shine as bright as with wires that can conduct the current better. I am mechanical, thus asking the peoples that knows more about this.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Has thanked: 70 times
Been thanked: 98 times
Post by Herrie » 01 Oct 2013 12:29
Even if I change the Bosch with Hella relays for the spot lights then the bright is different - much better with the Hella!
Post by Tinus lotz » 01 Oct 2013 13:01
It comes down to ohms law.....lol but if you put it just put big globes in anyway
Riaan Harding
Full Name: Riaan Harding
Nickname: Riaan Harding
Home Town: Meyerton
Current 4x4: Nissan Hardbody
Post by Riaan Harding » 05 Oct 2013 08:40
Marino4x4 wrote:I was looking around on the 4x4direct website and came across the Headlight Booster Harness they sell.
Hi Marino
What is the price on the wireing booster and were can you get it ?
we are also busy trying to make proper ones for HID and 55w + hella lights
Riaan
Kind Regards
Riaan Harding
Rugged 4x4 Fitment centre
E-mail riaan@rugged4x4.co.za
Website www.rugged4x4.co.za
Cell nr 0766571712
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 » 05 Oct 2013 12:56
Hi riaan.
die harnas is te koop by 4x4direct.co.za. Dit kos R285 met vat en posgeld is R35. Ek het maar die plunge gevat en n harnas bestel. Ek sal terugvoer op die post sit as ek dit gekry het. Dit behoort Dinsdag hier te wees.
groete.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 56 times
Post by Chris Skinner » 06 Oct 2013 22:39
Tinus - thanks for the prompt about OHM's law - its all about voltage drop at the actual point where wires connect to the globes. I am no expert but "Google is your friend" .... !
I suggest when engine running and lights on bright, measure your voltage at the battery, and also at the point where wires connect to the bulbs - if there is a voltage drop (more than about 0,2v = about 5% loss in light efficiency) then you are losing energy in the wires - then you should upgrade the wires and possibly the relay.
Found an article on the web, heres a short extract:
In many cases, the thin factory wires are inadequate even for the stock headlamp equipment. Headlamp bulb light output is severely compromised with decreased voltage. The drop in light output is not linear, it is exponential with the power 3.4. For example, let's consider a 9006 low beam bulb rated 1000 lumens at 12.8 Volts and plug in different voltages:
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
12.8V : 1000 lumens ←Rated output voltage
13.0V : 1054 lumens
13.5V : 1198 lumens
14.0V : 1356 lumens ←Rated life voltage
14.5V : 1528 lumens
The Europeans take a slightly more realistic with their voltage ratings; they consider output at 13.2v to be "100%". The loss curve is the same, though. When operating voltage drops to 95 percent (12.54v), headlamp bulbs produce only 83 percent of their rated light output. When voltage drops to 90 percent (11.88v), bulb output is only 67 percent of what it should be. And when voltage drops to 85 percent (11.22v), bulb output is a paltry 53 percent of normal! It is much more common than you might think for factory headlamp wiring/switch setups to produce this kind of voltage drop, especially once they're no longer brand new and the connections have accumulated some corrosion and dirt.
Its a very interesting article - for a better understanding read it here: http://www.danielsternlighting.com/tech ... elays.html
