Safety and high milage
bogeyman
Full Name: Christo Boegman
Nickname: Chris
Current 4x4: 2005 4.8 GRX
'95 patrol 4.2 (now 4.5) sgx also two 2005 4.2 diesel p/u also 3 safari workhorses.
Been thanked: 63 times
Post by bogeyman » 29 Sep 2013 16:39
After one of my old Safari pickups destroyed a Toyota bakkie last week ( it was the other guys fault) , I was prompted to relate some safety related incidents.
I was the first to fit 33" muds to one of my Safarie"s way back in the early eighties. Bigger wheels equals larger inertia and steering loads on the whole steering system. At about 500k km of mostly off road workhorse duty and high speed trips home for weekends , one of the tie rod ends ( the main one between the idler arm and two wheels) dislocated on a recce trip up a dry river bed in the blouberge near Alldays. No steering in a remote area.
The wear on that joint was enough to let the ball fall out of the housing! I pushed the joint back together and put a tie wrap around it and had to drive back to Pretoria like that because no replacement parts could be found. That truck is now on 680k km and going strong. (new tie rod though)
I check my vehicles regularly and there was no obvious play on that joint prior to the incident.
On a few occasions I have lost back wheels at speed due to the floating type wheel bearing failing and melting off the sideshaft ! These vehicles have permanent loads bolted on and work very hard. I regularly check and or replace these bearings and these failures occurred without warning.
Bottom line: Our trucks are well designed , but we sometimes modify and overstress them. They will last a long time , but old high mileage cars will need more than routine maintenance to keep them safe. Especially steering and brakes.
Full Name: Julius
Nickname: Jules
Current 4x4: GQ Patrol
Home Language: AFR
Has thanked: 65 times
Been thanked: 39 times
Re: Safety and high milage
Post by Jules » 29 Sep 2013 17:44
Yip Christo ek stem saam, my lorrie moet sy agter brake calipher seels vervang en ek het deesdae so bietjie van n knocking noise op my lorrie se stuur meganisme as ek draai ( dit kom en gaan egter nie permanent nie )
Hoe sal mens sien of jou agterste caliphers enkel of dubbel seels moet vat, toe ek op n stadium navraag gedoen het het die ou in Alberton waar mens die seels teen goeie prys kry gevra of my lorrie enkel of dubbel seels gebruik :think: ?
Die ander ding wat ek moet vervang is my radiator pype hul voel nie meer lekka soepel nie asof daar aan die binnekant goed is wat meegee as mens daaraan druk amper die gevoel van ogiesdraad?
Patrol 1995 SGL
aka "Nomakanjani"
ProComp Extreme A/T 31x10.5R15
ARB Bullbar
OME, Frontrunner Roofrack
60L Snomaster Freezer/Fridge
Has thanked: 289 times
Been thanked: 105 times
Post by Kagiso II » 29 Sep 2013 21:17
ek dink sodra LOBO loop [next week] moet mnr boegman hom bekyk ..
Jy behoort te weet hoe lyk n "gaar" ding wat 1,300,000 op het ?
:confused:
Has thanked: 547 times
Been thanked: 283 times
Post by Tinus lotz » 30 Sep 2013 05:30
Die patrols by ysters ons moet maar net meer maint. Doen ek dink jy weet meer as ander wat breek en wat nie .....
bogeyman
Nickname: Chris
Post by bogeyman » 30 Sep 2013 08:19
Jules,
Daar is n parte man by Global Nissan in Silverton Pretoria (Enzo) wat ou parte lyste aanhou en nogal heelwat oplossings vir my gegee het.
Hy kort net die vin nommer en n bietjie tyd. Dis nie goedkoop nie , maar partykeer is die duur opregte part die beter opsie.
Ek dink ek het al aandele daar !
Oom Mac,
Jy sal my maar moet nooi vir koffie as Lobo reg is , dan sal ek probeer lyk of ek slim is.
