TIPTRONIC IGNORANCE
GLAGS
Junior Member
Junior Member
Full Name: Grant Hobbs
Nickname: Wolly #1 or #2
Home Town: Stellenbosch
Current 4x4: Patrol 4.8 GRX 2004 and KZTE 4x4 D/C
TIPTRONIC IGNORANCE
Post by GLAGS » 11 Aug 2009 01:27
Hi All. New to this site & embaressed about my general ignorance. Anyway - "Hi all". Question: I've got a 4.8 GRX Tiptronic with 109,000km on the clock. Kids old enough for more serious safari now. I'd like to kit the vehicle with some better towing shocks and perhaps raise the suspension slightly. I heard a TIPTRONIC gearbox is a nightmare if you have to be towed in the bundus. Ag, please can someone provide a few pointers. Many thanks in advance. :doh:
2004 Y61 4.8 GRX
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Re: TIPTRONIC IGNORANCE
Post by Gerrit Loubser » 11 Aug 2009 05:03
It is not possible to start an automatic vehicle by towing it in gear. It is possible to tow it, though: place the transfer box in neutral and then the transmission is isolated from the rest of the drivetrain.
Tjaart
Nickname: TJ
Current 4x4: Patrol 4500 GRX
2000
Post by Tjaart » 11 Aug 2009 10:56
Hello Clags
Welcome to the site. Well done on your Patrol. It won't break and leave you stranded. Just look after it and don't murder it. :oldtimer: . If you are planning on doing serious towing, get either OME heavy duty coils and shocks at the back, or similar TJM XGS coils and shocks. This will also give a 50mm +- lift. The suspension will be very hard unladen, so keep that in mind. Otherwise go for a medium duty shock at the back and an airlift system in the coils! Works like a charm. :thumbup:
Like Gerrit pointed out, towing it is possible, but push start, no way. :thumbdown:. Patrols are known for their reliability and durability. So don't worry too much. I have heard about the auto gearbox getting hot when driven hard in low range - long periods of hard driving in thick sand or mud, while towing - but I've got a manual, so I am not familiar with the auto box. There are threads on this site regarding that, as well as on the Aussie website.
But first of all, gooi some :gotpics:
THE BRAVE
says
Aut PATROL aut nihil
Aut vincere aut mori
Ratau
Full Name: Danie Terblanche
Nickname: Danie
Current 4x4: 2000 Nissan Patrol 4.2 diesel
485 Nm@1300Rpm NA
Post by Ratau » 11 Aug 2009 14:10
Just keep in mind some late model transfer boxes have an oil pump driven by the input shaft similar like the auto boxes and therefore you can’t tow it for long distances even if you put it into nutral. The box will run with no oil feed and you could end up with huge repair cost. Rather disconnect the driveshaft at the pinion.
Danie
Live while you’re alive!
Current 4x4: None
Post by Gerrit Loubser » 11 Aug 2009 15:35
Ratau, as far as I know, the Patrol transfer case does not have an oil pump.
GLAGS
Junior Member
Junior Member
Post by GLAGS » 11 Aug 2009 21:19
Eish - what a lekker bunch of replies. Even my wife enjoyed your responses :clap: - thank you all!
2004 Y61 4.8 GRX
