Problem with fuel consumption
johannes.dieterich
Full Name: Johannes Dieterich
Nickname: Joggel
Current 4x4: Patrol 4.5l
Home Language: English/German
Post by johannes.dieterich » 15 Jul 2013 08:12
Hi there,
I am new in the block and a relatively greenhornish Patrol owner (2001, 4.5l petrol, injection).
Recently my fuel consumption suddenly shot through the roof (normally 6 to 7 l, now between 4 and 5)
and the idling is inconsistent (should be 900, but goes up to 1300 even if engine is warm).
I took it to my mechanic (Auto Rosen, Strydom Park) but he doesn't know what to do.
Does anybody have an idea what the problem could be?
Any advise would be most appreciated.
Johannes
marakasmalan
Full Name: Marnus Malan
Nickname: marakasmalan
Current 4x4: '94 Patrol SGL
Been thanked: 17 times
Re: Problem with fuel consumption
Post by marakasmalan » 15 Jul 2013 08:45
We all have a problem with fuel consumption - now with fuel prices rocketing 2nd hand prices should also drop and more patrols should come available on the floor as well.
Regarding your problem, first look at the usual supects: Filters, leaks, sparkplugs etc. also check thermostat - wrong coolant temperatures will yield inefficiency.
If there is no problem, check the brakes, especially the rear ones. Are they warm after a drive even though used very sparingly. Also check the handbrake.
Then, use the EOBDII tool to reset the ECU, or disconnect the battery for 30mins.
Has thanked: 564 times
Been thanked: 294 times
Post by Tinus lotz » 15 Jul 2013 19:19
We all love ur trollies if you got 6-7 km per liter and you didnt change any thing like tires ect then u have a problem
I would suggest that u take it to Graham cumming . He has one of those 4.5 also and he works on a lot of the members cars
he has all the tools to reset ecu s ect and knows the electrial system values out of his head . Mabe your M A S or something is giving problems . Also the feul pump can do the same . Speak to the patrol professor he wil sort u out :thumbup:
Current 4x4: 1998 Nissan Patrol 4500 GRX, 2011 Zook
Has thanked: 109 times
Been thanked: 88 times
Post by Jorrie » 15 Jul 2013 19:43
Maak soos Tinus sê. Vat jou Trollie na Graham Cumming toe. Hy sal jou Trollie uitsorteer.
4500 GRX
Jimny
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 16 times
Been thanked: 76 times
Post by Marino4x4 » 02 Aug 2013 09:52
Hi Johannes
Could you sort the idling problem out? My idling is also not constant and it is independent of engine temperature. Some times when the engine is hot it will still be 1300 or so? Fuel consumption is 5-6km/l. Would like to know if it can be sorted.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Post by Tinus lotz » 02 Aug 2013 13:18
[quote="Marino4x4"]Hi Johannes
Graham checked the feul pressure and it was way off ...needed a new pump unsure if its sorted they were only getting radiator from tombo today but johannes will let us know once all is done .......nice to go and visit Graham and see 4 patrols in one workshop at the same time ....
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 42 times
Post by David » 02 Aug 2013 13:49
Tinus & Marino, doen die 'Accelerator Pedal Released' en 'Throttle valve closed' en 'Idle air volume learn' prosedures - dit behoort dit reg te maak anders is dit iets eenvoudig soos die rubber grommet op die punt van jou accelerator kabel wat nie lekker geseat is nie. Kyk of jou kabels nie te styf is nie - hulle moet so 'n bietjie speling hê .... :thumbup:
Hier is die link : 'Learn Procedures'
David
ARB Bullbar, TJM 2" Suspension, Snorkel, 285/70/17 BFG KO2's, 40L Engel, Nuvi 1410, TPMS, SatNav
Marino4x4
Nickname: Marino4x4
Post by Marino4x4 » 02 Aug 2013 15:27
Thinus ek het al my pomp vervang en die kar na dit ge-dyno.
David ek het dit vanoggend geprind en beplan om dit vanmiddag as ek by die huiskom te doen. Hoop dit sal die dinge oplos. Dankie vir die post. :thumbup:
Patrol 4.5 GL 1998
Terrain 4X4 Parts
David
Nickname: David
Post by David » 02 Aug 2013 21:40
Ek hou duim vas dit werk vir jou :thumbup:
Tim
Junior Member
Junior Member
Full Name: Timo van der Smit
Nickname: Tim
Home Town: Windhoek
Current 4x4: Nissan Safari
Nissan Patrol GU
Landrover Defender 90 2.8
Toyota Land Cruiser P/U 4.5
Been thanked: 10 times
Post by Tim » 23 Aug 2013 13:50
Marino
Kan jy vir ons uitsluitsel gee of die prosedure vir jou gewerk het, aldan nie wat anders die fout en oplossing is.
Return to “08. Your Patrol”
