2006 Nissan Patrol 4.8 stalling at lower RPM
Mustang3897410
Full Name: Sean Ryder
Nickname: Seany Boy
Home Town: Dubai
Current 4x4: 2006 Nissan Patrol 4.8L Petrol
Has thanked: 1 time
Post by Mustang3897410 » 01 Jul 2013 18:28
Hi guys,
I seem to have multiple issues with my Patrol. I have tried a few mechanics, ended up spending a lot of money but could not get them to fix it for me. It's a 2006 Nissan patrol 4.8 petrol. The only mod is a K&N air intake system installed.
Here are some of the observed issues.
The vehicle requires enormous amount of acceleration to get the vehicle moving from stand still. If I accelerate moderately the vehicle struggles and jerks but forward movement becomes very slow.
In soft sand or when climbing sand dunes the vehicles so badly and barely makes it up the dune.
At one point I tried drive across a dune from the side. As I was driving across the vehicles started losing power and took me straight down instead of going in a straight line.
Hill climbing also I have similar situations where the vehicle struggle to get up there. The vehicle also takes time to accelerate. When you push the pedal from a stop light the vehicle roars and jerks and starts off slow like as if it's stalling. But then once the RPM goes up to 3k it jumps and moves ahead fast. This issue is always there with all the gears.
Due to this issue I have to accelerate fully all the time. Sometime when u accelerate fully, the acceleration does not go up and the needle stays at 1 to 2k Rpm and This happens mostly when im making a turn where it gets dangerous as the oncoming driver assumes that i will make the turn before he gets near but my vehicle stalls and i get to release the pedal and accelerate again.
This is my daily driver. I'm wasting a lot of money of fuel. I have already checked the normal fuel consumption of the patrol which is much much less than what my vehicle is drinking.
I would really appreciate any help with this.
Has thanked: 564 times
Been thanked: 294 times
Re: 2006 Nissan Patrol 4.8 stalling at lower RPM
Post by Tinus lotz » 01 Jul 2013 18:52
Sounds like perfomance chip problems ........take it to graham cumming he wil sort it chop chop
Mustang3897410
Nickname: Seany Boy
Home Town: Dubai
Has thanked: 1 time
Post by Mustang3897410 » 01 Jul 2013 20:06
Will give it a shot and let you know. Thanks for the response.
Current 4x4: 1998 Nissan Patrol 4500 GRX, 2011 Zook
Has thanked: 109 times
Been thanked: 88 times
Post by Jorrie » 01 Jul 2013 22:36
Sean
From what I can gather you seem to be in Dubai. Still give Graeme Cumming a call. He will certainly be able to give you good advice.
4500 GRX
Jimny
dieselfan
Full Name: Roy Markham
Nickname: Roy
Post by dieselfan » 01 Jul 2013 23:15
Mustang3897410 wrote: This happens mostly when im making a turn where it gets dangerous as the oncoming driver assumes that i will make the turn before he gets near but my vehicle stalls and i get to release the pedal and accelerate again.
Tinus has it, the ECU?
Also you should try the D3 there's a 2 sec delay on pull off, embarrassed myself loads "running" a stop street only to drift across :redface: and then surge like a train.
Wheels
Post by Wheels » 02 Jul 2013 08:47
You could have a small hole between the intake manifold and the MAF. Or the more expensive side could be a faulty MAF. With your K&N filter you could have damaged you MAF. Use the original Nissan filter especialy in the dunes and sand driving that you do.
Mustang3897410
Nickname: Seany Boy
Home Town: Dubai
Has thanked: 1 time
Post by Mustang3897410 » 02 Jul 2013 16:18
Jorrie wrote:Sean
Yes, I'm in Dubai. I will surely ring up and see what I can get out of it. Thanks. Appreciate your help.
Mustang3897410
Nickname: Seany Boy
Home Town: Dubai
Has thanked: 1 time
Post by Mustang3897410 » 02 Jul 2013 16:23
Wheels wrote:You could have a small hole between the intake manifold and the MAF. Or the more expensive side could be a faulty MAF. With your K&N filter you could have damaged you MAF. Use the original Nissan filter especialy in the dunes and sand driving that you do.
I double n triple checked the intake set up. No hole to be found anywhere. The last time I had some rough idling the mechanic who worked on the car had removed the air intake to spray some cleaner inside the throttle body. This issue started a few days thereafter.
I'm not sure if there is some kind of leak in the set up when he fixed it back.
Mustang3897410
Nickname: Seany Boy
Home Town: Dubai
Has thanked: 1 time
Post by Mustang3897410 » 02 Jul 2013 16:30
Jorrie wrote:Sean
Where can I find his no?
Post by Tinus lotz » 03 Jul 2013 01:07
The man is on holiday till the 8 of this month here is his no 012 651 3447
