Sticky Speedometer (VDO specialist needed)
Nickname: Witblits
Has thanked: 41 times
Been thanked: 138 times
Post by Alex Roux » 06 Jun 2013 21:55
Hi Guys
I've had this problem or a while and it is time to fix it. Graham Cummings in Centurion can help, but only operates in the week and so do I. so I cannot drive through to him.
My Patrol's speedomoeter is stuck after I had a light bulb replaced, behind the dash.
I do not want to take it back to the same place as I suspect they worked a little rough with my car - hence the problem. They deny causing it anyway and it is not worth fighting with them.
I am convinced it is the speed needle that is a little sticky and not a gear problem. I.e. the odometer clocks fine, and all the other readings (rev counter etc. works fine).
Any idea where in the West side of Jhb (Randburg area) I can take it?
E.g. a VDO specialist?
Skilpad & Shortie
Has thanked: 291 times
Been thanked: 110 times
Re: Sticky Speedometer (VDO specialist needed)
Post by Kagiso II » 07 Jun 2013 00:36
'Lexi -- bring to Oompie in Ben ooni - I wil take to Graham in daytime [just make appointment wi' him first] (and chex widt da oompie what day him also not sleepsing latest :-) QQQ
[ek is wakker tot tye soos hierdie .. 00:40 :oldtimer:
Nickname: Witblits
Post by Alex Roux » 07 Jun 2013 07:16
Sjoe. om Oom se Engels te verstaan. Ek dink dit is 'n plan. Sal laat weet dankie.
Skilpad & Shortie
Has thanked: 71 times
Been thanked: 98 times
Post by Herrie » 07 Jun 2013 07:22
Jare terug het alle Volksies ook VDO's gehad en as die naald by die VDO uitgekom het, het dit beteken - Volksie Donner Om! :rolling:
Has thanked: 300 times
Been thanked: 369 times
Post by Peter Connan » 07 Jun 2013 14:18
Years ago, I used these guys: http://www.sayellow.com/@2?wr=10&Cli_Re ... er=348,919
Obviously, I can't comment on their level of service now, as that was 15 years ago.
