Domestic 12V Water Pump
Current 4x4: 1998 Nissan Patrol 4500 GRX, 2011 Zook
Has thanked: 119 times
Been thanked: 95 times
Post by Jorrie » 31 May 2013 18:41
Can anybody help me? Where can I find a 12V Water pump to fit in the fresh water line from the water tank built into my Troll?
4500 GRX
Jimny
Has thanked: 570 times
Been thanked: 296 times
Re: Domestic 12V Water Pump
Post by Tinus lotz » 31 May 2013 18:46
Jorrie have one we use on the boats for keeping live bait alive come have a look I think they sell for around 300 rand
Post by Jorrie » 31 May 2013 19:47
Thanks Tinus. Where can I buy one?
4500 GRX
Jimny
Has thanked: 307 times
Been thanked: 381 times
Post by Peter Connan » 01 Jun 2013 07:07
Jorrie, the caravan shops should sell pressure pumps. These are more expensive then the pupm Tinus mentions, but will "hold" pressure when you close the tap (IE stop running), and also are not damaged by running dry (see the latest issue of WegRy/DriveOut). Alternatively you can also buy one of these small shower sets at a camping/caravan shop for a couple of hundred bucks and cannabalise the pump?
Post by Jorrie » 01 Jun 2013 09:54
Peter
Thanks, I will have a look today. :salute:
4500 GRX
Jimny
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Been thanked: 74 times
Post by ChristoSlang » 01 Jun 2013 11:22
Jorrie, where did you fit the water tank? What size and type?
I'm out of "Chuck projects" at the moment :shrug:
Christo (the snake man)
Post by Jorrie » 01 Jun 2013 13:57
Christo
I fitted a drawer system in the back of the Troll. A 50 lt water tank (Pioneer plastic) is fitted athwartships behind the middle row seats but in front of the drawer system (above and slightly ahead of the rear axle). Works very well. All I want to do now is to get some pressure in the waterline without pressurising the tank. The gravity feed is too slow for my liking.
If you happen to be in my area you are welcome to come and have a look. Else you can have a look at SANDWANI. :salute:
4500 GRX
Jimny
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Has thanked: 7 times
Been thanked: 19 times
Post by Bruin Beer » 01 Jun 2013 18:11
Jorrie,
How about a pic or two?
Thanks.
Bruin Beer
Post by Jorrie » 01 Jun 2013 19:22
Riaan
Ek sal môre 'n plan maak en 'n foto of twee op plak.
4500 GRX
Jimny
Has thanked: 292 times
Been thanked: 111 times
Post by Kagiso II » 01 Jun 2013 21:35
Jorrie wrote:Christo
JOR -- ek het vanmi8rrag n aHannes van Zyl se set-up gekyk -- hy het daai prop n gat in gemaak - en 'n filter van spons bo monteer - nou haal daai tenk asem wyl hy water tap en daai water lkoop amper TE vinning
Voor jy begin POMP -- gee eers die asem ding n kans??? -- "release sommer net die prop ??
[maar so slim en skerp soos jy is het jy dit w2aarskynlik reeds gedoen .. :think: :think: :oldtimer: :oldtimer:
Return to “16. DIY Projects”
