Lifting Struts (or whaever they called)
Other Queries
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 56 times
Post by Chris Skinner » 01 Feb 2013 11:33
Where can one buy those lifting struts - eg used for holding up the bonnet??
Agents are very expensive...
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 16 times
Been thanked: 81 times
Re: Lifting Struts (or whaever they called)
Post by Marino4x4 » 01 Feb 2013 11:54
Midas sells the Gabriel ones. They can adjust the pressure to suite your needs.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Chris Skinner
Nickname: Chris
Post by Chris Skinner » 01 Feb 2013 12:12
Thanks! I phoned them - problem is they do not seen have for the back window lifting strut for a Jeep Cherokee. Will keep looking.
Current 4x4: 1998 Nissan Patrol 4500 GRX, 2011 Zook
Has thanked: 119 times
Been thanked: 95 times
Post by Jorrie » 01 Feb 2013 12:19
Talk to Graham Cumming. He can help you.
4500 GRX
Jimny
AndriesS
Full Name: Andries
Nickname: None
Home Town: None
Current 4x4: None
Has thanked: 15 times
Been thanked: 25 times
Post by AndriesS » 01 Feb 2013 14:20
Or goto the Bosch Diesel electric in Churhc str pretoria West. They can increase the pressure and refill them later
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Has thanked: 7 times
Been thanked: 19 times
Post by Bruin Beer » 03 Feb 2013 17:31
Chris,
They don't have the Jeep item listed.
You will need to take the sample.
I bought at Midas Midrand (John) a set for the tail gate window on my WJ Grand Cherokee about 18 months back.
Hope this help.
Bruin Beer.
AndriesS
Full Name: Andries
Nickname: None
Home Town: None
Current 4x4: None
Post by AndriesS » 04 Feb 2013 09:31
A problem I had with the spares guys are that they match more or less on length and never on pressures. My wife's Merc has a massive glass bootlid and the new ones I bought from the A zone nearly decapitated her when it unexpectatley closed on her neck. Since then I rather go to Diesel Electric, they start by measuring the existing one, then pump a new one to a higher pressure as required. On top they were nearly 50% cheaper than the spareshop
Carel
Full Name: Carel Vos
Nickname: Carel
Home Town: Germiston
Current 4x4: 84 Safari
2001 Patrol 4.5 GRX
Been thanked: 9 times
Post by Carel » 04 Feb 2013 10:29
You can also try MacNaughtans, they can supply the correct length and pressure of the existing ones.
"Life is what's happening while you're busy making other plans" Celine Dion
Bruin Beer
Nickname: Rooian
Post by Bruin Beer » 04 Feb 2013 15:30
Andries,
I was told by Midas that they order the Safaries from Diesel Electric in PTA central.
One less middle man.
Bruin Beer.
Return to “23. Other Queries”
