Skottel Braai
Izak
Full Name: Izak
Nickname: Sakkie
Skottel Braai
Post by Izak » 17 Sep 2012 08:39
HHello
I need a bit of advice please.
In anticipation of this weekend's short holiday in Kruger we decided to clean and test all the gas equipment this weekend. While busy with that we decided to do the Kruger Brunch thing on the Cadac Skottel Braai. The Skottel is a great invention but impossible to do more than one fried egg at a time because of the shape.
So I took a flat bottomed steel camping pan (This thing is about 5mm in width and fits very nicely in the skottels gas braaier area). After about 15 minutes on the flame the gas braaier collapsed. From the pieces it looks as if the piece of steel lying on top of the flame made the aluminium to hot and it melted or became so brittle that it broke.
My question is if this has happened to anybody before and should this even be possible to heat that aluminium part to the extent that it melts?
I will take some photos tonight and post it tomorrow.
Has thanked: 291 times
Been thanked: 110 times
Re: Skottel Braai
Post by Kagiso II » 19 Sep 2012 18:07
eerste keer in my leeeeewe lattik van die hoor -- Sakkie -- kom met daai kiekies lattik sien?
ek het juis 'n klomp VOLVANO panne / potte gekoop om oppi Cadac te sit assik boskos maak ..
Peter Vee
Full Name: Peter Viljoen
Nickname: Peter Vee
Home Town: Roodekrans
KLR 650 ;)
Re: Skottel Braai
Post by Peter Vee » 02 Oct 2012 06:26
Gee whiz Izak, never heard of that happening before. I have a cadac skottel which I use from time to time but switched to an Avla 3 burner fitting with a cast iron top... griddle one side and flat the other which does eggs etc well.
Hope someone can shed light on what caused the issue you have described.
Peter
Peter Vee
Izak
Full Name: Izak
Nickname: Sakkie
Re: Skottel Braai
Post by Izak » 03 Oct 2012 08:33
Attached the photos of the skottelbraai as promised.
It is a bit dirty as it was lying outside since the melt down. :rolling:
The burner seems to be bending down, might be from the heat??
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 16 times
Been thanked: 81 times
Re: Skottel Braai
Post by Marino4x4 » 03 Oct 2012 12:18
Hi Izak
What you need is the following:
1: Oil Catch Can
2: Dawes and Needle Valve
3: EGR Block plate
4: Boost gauge
5: EGT gauge
Whala!!!! No more skottelbraai hand grenade! :lol: :lol: :lol:
Truth, I have never seen something like this.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Re: Skottel Braai
Post by Gerrit Loubser » 03 Oct 2012 12:58
Marino4x4 wrote:1: Oil Catch Can
3: EGR Block plate
4: Boost gauge
5: EGT gauge
All of the above collectively known as CADS (Cadac Anti-Detonation System). :biggrin:
Has thanked: 260 times
Been thanked: 257 times
Re: Skottel Braai
Post by ricster » 03 Oct 2012 13:37
:rolling: :rolling: :rolling: ....
Izak.... my donder .... were you blowing acetylene through there.... :rolling: :rolling: ..... I've never seen that before ..... ever!!
SCUBA Patrol
Full Name: Phillip Jacobs
Nickname: Phillip
Has thanked: 23 times
Been thanked: 21 times
Re: Skottel Braai
Post by SCUBA Patrol » 03 Oct 2012 14:39
Izak, stuur die kiekies aan vir Cadac, laat ons hoor wat hulle se?
Ek gebruik self die Alva 3 burner met 'n aluminium wiel bo op en het nog nooit so iets oorgekom nie en daai Alva maak die lewe warm daar onder!
Phillip
Phillip
2006 3l with MADMAN
davejones
Full Name: David Jones
Nickname: David
Home Town: Lagos, Nigeria
Been thanked: 5 times
Re: Skottel Braai
Post by davejones » 14 Apr 2013 17:50
better than this happening..... :oldtimer:
moz 080.jpg (3.95 MiB) Viewed 2976 times
moz 079.jpg (3.74 MiB) Viewed 2976 times
moz 076.jpg (3.65 MiB) Viewed 2976 times
moz 082.jpg (3.73 MiB) Viewed 2976 times
An ox, but with balls !!!
Re: Skottel Braai
Post by Kagiso II » 14 Apr 2013 18:05
nee wragtag -- ek het al n bord gegooi as die kos slehg is -- maar so erg was die Dwergi se kook darem nog NOOIT nie .. wie't opgeruim? Die kok met die sleg resep of die eter wat sy goeters uit die kot gegooi het ??
:rolling: :rolling: :rolling: :rolling:
[hoop niemand het seergekry nie? en dat die huisdiere [kat, hond, budjie nog ammal ook orraait is..]
:biggrin:
