Patrol 3.0DI clutch shudder
pdasilva
Full Name: Paulo
Nickname: da Silva
Home Town: Kempton Park , Gauteng.
Current 4x4: Nissan Patrol 4.8grx
Suzuki Sidekick 1.6
Been thanked: 4 times
Post by pdasilva » 31 Aug 2012 16:02
I have a problem with clutch shudder at low revs when driving off in 1st gear as well as reverse. This problem gets worse after about 20km when driving in traffic. Pulling away with higher revs takes away the shudder and sometimes this is what i have to do to prevent the horrible vibrations.
My patrol currently has 150k on the clock and its a 2005 model and i bought the car second hand which had an engine rebuild at about 120k. Would this be the signs of a clutch kit replacement?
Has thanked: 291 times
Been thanked: 110 times
Re: Patrol 3.0DI clutch shudder
Post by Kagiso II » 31 Aug 2012 16:37
Haij-a -- YES .. BUT it could also be the universal joints on the prop shaft --
In Pretoria area I can recommend AUTO BOX [they do manuel box / clutch too]
other parts of world or country .. sorry, no no
OH - if you can get a VALEO .. they just are that much better [ZACHS as 2nd choice]
Has thanked: 565 times
Been thanked: 295 times
Post by Tinus lotz » 31 Aug 2012 17:26
Not. Vey familair with patrol cluch but put in 3 gear and see what happens when you. Tray to pull away ... If it slips ... New clutch. Mabe some oil is leaking on to it?
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser » 31 Aug 2012 18:15
Could unfortunately also be the dual mass flywheel that is kaput.
martyn
Full Name: Charles Fry
Nickname: Charlie
Current 4x4: Patrol 4.5
Has thanked: 9 times
Post by martyn » 01 Sep 2012 09:01
Before you take out gearbox etc, check the gearbox and related mountings are not broken, had experiance where gbox mounting was kaput and caused same type of problem. Just my :mytwocents:
Diem Dulcem Habes
Have a good day
pdasilva
Full Name: Paulo
Nickname: da Silva
Suzuki Sidekick 1.6
Post by pdasilva » 03 Sep 2012 08:52
Pulling away in 2nd gear I have no clutch shudder. I think pulling away in 3rd gear is a bit impossible on the 3.0di.
Im going to have a look under the car tonight to check the gearbox mounts as well as the propshaft universal joints. I can get an aftermarket clutch kit for about R2100 but if its the Dual mass fly wheel then I will need to purchase from the stealers.
Grant
Full Name: Grant Francis
Nickname: Grant
Home Town: Mid Rand Estates
Current 4x4: Ford Ranger
Mini Countryman
Specialized Epic
Specialized Crave Single Speed
Been thanked: 21 times
Post by Grant » 03 Sep 2012 09:13
MorniNG Paulo,
I have a 4,2 TD and had a similar problem. Was the clutch, and main reason was that the springs that damp chatter, where totally worn out.
Specialized Epic
Grant
Nickname: Grant
Mini Countryman
Specialized Epic
Post by Grant » 03 Sep 2012 09:17
10 Common Causes of Clutch Shudder from the net.
Oil Contamination of Clutch Plate from Engine or Gearbox Seal Leakage
Loose or Worn Engine Mountings
Worn Shackles or Loose U Bolts (Where applicable)
Worn or damaged Universal Joints or CV Joints
Drive Shaft Centre Spigot Bearing worn or Failure (Where applicable)
Broken Drive Straps on Cover Assembly through driver abuse i.e. Down changing or Savage clutch engagement.
Incorrect driving habits, Driver induced shudder is also caused by abrupt clutch engagement or releasing, the clutch should always be feathered on release or engagement rather than being jabbed when releasing or engaging.
Worn Pilot Bearing/Spigot Bush-Dry Gearbox Snout or Clutch Disc splines.
Missing Flywheel Dowels
. Incorrect installation proceedure i.e. Clutch Disc Bent during installation by hanging gearbox or incorrect clutch adjustment i.e. Clutch over adjusted causing over centering which can create premature engagement.
Specialized Epic
Has thanked: 300 times
Been thanked: 371 times
Post by Peter Connan » 04 Sep 2012 11:25
Grant wrote:MorniNG Paulo,
As I understand it, the 3l doesn't have these springs in the clutch plate, but has a dual-mass flywheel instead.
As Gerrit said, this could very well be the problem, but before you remove the engine (I am told this is easier than dropping the gearbox), check all the mountings, as well as rear suspension bushes and driveshaft.
pdasilva
Full Name: Paulo
Nickname: da Silva
Suzuki Sidekick 1.6
Post by pdasilva » 05 Sep 2012 19:10
OK so I checked the gearbox and engine mounts, they look perfect. The prop and universal also look perfect and should not be worn at this low km.
So I presume next step is to remove the gearbox or engine to inspect the clutch and fly wheel.
Does anybody know of a good workshop in the JHB area preferably somebody who knows Patrols.
