Wheel and tyre advise
If you supply and/or install equipment or accessories for Patrols, then please tell us about your business.
Current 4x4: 1998 Nissan Patrol 4500 GRX, 2011 Zook
Has thanked: 109 times
Been thanked: 88 times
Re: Wheel and tyre advise
Post by Jorrie » 11 Jul 2012 00:36
Jules wrote:I am considering changing my original Patrol 7JJ to black 8JJ steel rims, had some leaking problems seems to be solved now but it is always in the back of my head, seems I can get 5 rims for R2500.
It seems like a fair price. I was quoted R600 per rim last week.
4500 GRX
Jimny
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
Home Town: Cape Town ,but raised in the Tanskei
Has thanked: 1 time
Been thanked: 53 times
Post by Russ Kellermann » 11 Jul 2012 09:38
@ Jules, wow, are those really the original Nissan GQ steels, very cool. Similar to the smith wheels / pro whites, but stronger i bet?
@ Sias , yes, im always looking for steel wheels, i seem to bugger mine pretty quickly. Im looking for 7j (or jj) normal offset ( -0 offset). Im having problems getting mine true, but it appears its also the BFG that are causing kak. So im sceptical to go to pro-whites or smith wheels again.....
If either of you chaps are considering selling let me know ahead of time. Thanks.
Has thanked: 285 times
Been thanked: 366 times
Post by Peter Connan » 11 Jul 2012 10:02
Russ, the original Nissan GQ steel wheels are the worst parts of the whole car.
It's the only part I know of on the GQ that was the subject of a recall unlimited in terms of age or mileage. They are IMO considerably weaker than either the Smith's/Pro Whites or the steel rim on the Y61/GU.
On my car, three of the five were cracked. the previous owner had fitted tubes to "mask"the problem, the result was that I had a blowout on the frweeway when the crack extended to such an extent that there was a 10mm gap between the two halves, and the tube burst. Fortunately it was on a rear wheel.
Henk&Toni
Full Name: Henk Meyer
Nickname: henk
Current 4x4: Patrol EFI 4.5
Home Language: Afr & Eng
Post by Henk&Toni » 13 Jul 2012 02:06
Peter Connan wrote:Is your 4.5 manual or auto?
I have heard froam a couple of people that 285/75 R16 causes the auto-box to "hunt" at freeway speeds, but it is certainly better for most off-roading.
They should fit fine on your standard rims (if they are 16").
Mine is a manual!!4.5
Henk&Toni
Nickname: henk
Post by Henk&Toni » 27 Jul 2012 04:41
Russ Kellermann wrote:I would definitely go for a 285.75.16 on a 7jj or 8jj rim.
Could anyone refer me to a tyre dealer as im looking for 6 mudterrein tyres ...285.75.16,and what type i should put on,And any advise on lifting my 4.5 patrol 6inches..many thanks :biggrin:
Post by Jorrie » 27 Jul 2012 05:53
There's lots of discussion about MTs and lifting on this forum. Also see the "WegRy" or "Go" Magazines of November 2011. :wink:
4500 GRX
Jimny
Post by Jorrie » 27 Jul 2012 05:57
Also contact G-Man in Noordhoek. He would most certainly be able to give you excellent advice.
4500 GRX
Jimny
Return to “22. 4x4 Suppliers/Installers”
