SERVICE ITEMS
KOOS BEST
Nickname: Kosie
Home Language: TWEETALIG
SERVICE ITEMS
Post by KOOS BEST » 22 Jun 2009 21:44
Hi , today I ran into a spare shop to buy filters and oil for my 3.0d GRX. 190 000KM service. I forgot my diary at work with all the part numbers etc. At both shops they gave me a filter for the Hardbody, I told them its wrong cause the Patrol uses a cartridge and not a metal filter. The Spares shops I go to always seem to have terrible info for Patrols on their catalogues.
I request that we have a template form for all Patrol models which states all the relevant parts you need to maintain your vehicle.Pse somebody that can create something like it its nice to have , you print it and keep it in your car.
For Example;
Safari,Patrol Model__________ Engine______________
Oil Type and qauntity_______________________________
Gearbox Oil__________________________
Transfer Case Oil__________________________
Differential Oil________________________
Grease Type__________________________
Oil filter GUD__________ FRAM___________
Fuel Filter GUD_________ FRAM ___________
Air Filter GUD___________FRAM___________
Spark Plugs Brand name____________________________ Gap_______________________
Fan Belts Main_______________ A/C_____________________ Aux_____________________
Front Brake pads_______________________________________
Rear Brake Pads________________________________________
Windscreen Wiper Blade Length_______________________________
Rear Wiper Blade length_________________________________
Above is some of the items I think thats important , pse add some which you would like to see. Koos
Land Rover Discovery 3 TDV6
KOOS BEST
Nickname: Kosie
Re: SERVICE ITEMS
Post by KOOS BEST » 23 Jun 2009 07:50
Items for Y 61 GU 3.0D Vin no; JN1TESY61Z0535612
OIL FILTER GUD M10 FRAM CH 9540
AIR FILTER GUD ADG 1010
DIESEL FILTER GUD________ FRAM P5138
FRONT PADS FERODO D3384
REAR PADS FERODO D 3386
OIL 8.2 LT
RADIATOR 13.8LT
For my Y 60 GQ TD42 vin no JNTNRSY6040510774
OIL FILTER GUD 2 X Z 292
DIESEL FILTER FRAM 4922
AIR FILTER GUD 1001
FRONT PADS FEREODO FDB 643
REAR PADS FERODO FDB 937
GEARBOX CASTROL VMX 80 MANUAL 4 LT
TRANFER BOX CASTROL VMX MANUAL 1.5 LT
REAR DIFF CASTROL LSX 90 2 LT
FRONT DIFF CASTROL EPX 80/90 HYPOID 5.2 LT
Does anybody have more info, like fan belts etc.
Koos
Has thanked: 198 times
Been thanked: 61 times
Re: SERVICE ITEMS
Post by JohnBoyZA » 23 Jun 2009 09:44
Ant idea why the rear and front diff would use different oil?
Flickr: http://www.flickr.com/photos/jhemurray/sets/
Full Name: Julius
Nickname: Jules
Current 4x4: GQ Patrol
Home Language: AFR
Has thanked: 79 times
Been thanked: 43 times
Re: SERVICE ITEMS
Post by Jules » 23 Jun 2009 10:05
John easy answer because the one is in the FRONT and the other in in the REAR :lol:
My 1995 SGL 4.2 Petrol
Brake Pads Rear ( Ferro Brake |) - FDB937
Gearbox oil - Amsoil 75W90
Airfilter - My petrol Patrol uses the diesel spec air filter as per Spares Shop catalogue
Have not yet replaced front brake pads when I enquired about them the Spares Shop said sorry must get from agents???
Patrol 1995 SGL
aka "Nomakanjani"
ProComp Extreme A/T 31x10.5R15
ARB Bullbar
OME, Frontrunner Roofrack
60L Snomaster Freezer/Fridge
Has thanked: 70 times
Been thanked: 98 times
Re: SERVICE ITEMS
Post by Herrie » 23 Jun 2009 10:12
The Castrol LSX is for LSD diffs!
Abri Hoffman
Full Name: Abri Hoffman
Nickname: Abri
Home Town: Live in Ceres / Work in Cape Town
Current 4x4: 2006 Nissan Patrol 4.8 GL
1994 Nissan Patrol 4.2 SGL
Been thanked: 7 times
Re: SERVICE ITEMS
Post by Abri Hoffman » 23 Jun 2009 10:54
Jules wrote:John easy answer because the one is in the FRONT and the other in in the REAR :lol:
Jules, where do you buy the amsoil from, I have been recommended to use it when I bought my Cruiser few years back but could not find it then.
2006 4.8 GL
1994 4.2 SGL
Metalian Mini
Bundutop on each
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Air Filter Element for TB45E
Post by Gerrit Loubser » 11 Jul 2009 16:16
Does anyone know of an after market air filter element for the TB45E motor in the Y61 4.5 GRX Patrol? I am busy gathering the parts and fluids for my 220000km service and it seems neither GUD nor Fram have an air filter element in their catalogues. Has anyone found a GUD/Fram that works?
So far I have found the following information for my 1999 4.5 GRX M/T:
Safari,Patrol Mode:l__Y61_(4.5 GRX M/T)_______ Engine:_TB45E_____________
Oil Type and qauntity:_API SG, 7.6 l, Castrol Magnatec 10W40______________________________
Gearbox Oil:_SAE 75W90 API GL-4, 3.8l, Castrol BOT 130M_________________________
Transfer Case Oil:__________________________
Differential Oil:________________________
Grease Type:__________________________
Oil Filter Nissan:_15208-31U00 or 15208-31U01___________GUD:_Z226__________ FRAM:_PH7317__________
Fuel Filter Nissan:_____________________________________GUD:_E13___________ FRAM:_G4777___________
Air Filter Element Nissan:_16546-VB000 or 16546-VB700___________ GUD:_______________FRAM:__________________
Spark Plugs Code:_BPR5E-11__________ Brand name:____________________________ Gap:_1.0 mm to 1.1 mm__________
Fan Belts Main:_______________ A/C:_____________________ Aux:_____________________
Front Brake Pads:_______________________________________
Rear Brake Pads:________________________________________
Windscreen Wiper Blade Length:_______________________________
Rear Wiper Blade Length:_________________________________
KOOS BEST
Nickname: Kosie
Re: SERVICE ITEMS
Post by KOOS BEST » 11 Jul 2009 20:44
Gerrit, I see the Ozzies say the only part you must buy genuine from Nissan is the air filter.
Do you perhaps have a chart or diagram with all the grease nipple points on the GU.I would like to give mine a good grease lube service myself, to see what nipples are blocked or dont work.
Koos
Current 4x4: None
Re: SERVICE ITEMS
Post by Gerrit Loubser » 11 Jul 2009 21:22
Koos, I also read that on the Aussie forum. I wonder whether there might be a Donaldson air filter element that would work, though.
The maintenance section of the Y61 manual does not mention any other grease nipples than those on the propshafts. Other items that need greasing are the front wheel bearings and the auto hubs, but of course these are not greased via grease fittings.
Re: SERVICE ITEMS
Post by Herrie » 26 Jul 2009 18:59
I have a K&N E-9266 in Ungili.
