Communication & Navigation Equipment: VHF, UHF, GPS, Satellite phones ETC.
Full Name: A.G.HOLMES
Nickname: G-MAN
Home Language: Engels
Been thanked: 9 times
Post by G-MAN » 12 Sep 2009 01:15
Can T4A work on a nuvi 205w? :helpsign:
Sucks Gas and Hauls Ass!
Abri Hoffman
Full Name: Abri Hoffman
Nickname: Abri
Home Town: Live in Ceres / Work in Cape Town
Current 4x4: 2006 Nissan Patrol 4.8 GL
1994 Nissan Patrol 4.2 SGL
Been thanked: 7 times
Re: NUVI 205W
Post by Abri Hoffman » 12 Sep 2009 01:30
Hiers 'n vergelyking van die Nuvi 205W en die Nuvi 765: ... duct=14926
T4A werk 100% op die Nuvi 760 so ek sien geen rede hoekom die 765 anders sal wees nie.
Uit die vergelyking lyk dit vir my of dit wel sal werk.
Ek gebruik huidiglik 'n Garmin iQue 3600 en T4A werk, dit werk ook op die Quest.
Dus sal ek verbaas wees as dit nie werk nie. Het dit egter nog nooit getoets nie.
Hiermee 'n extract van T4A:
"Nüvi™ and Zumo™ Owners
T4A GPS Maps are compatible to the Nüvi™ and Zūmo™ series GPS from
Garmin®. Most Nüvi™ and Zūmo™ units are sold without a CD or DVD
containing MapSource®.
Maps are generally sold on SD card and the card simply replaced to load new
maps. T4A GPS Maps are supplied on CD and need to be loaded to your GPS
using either MapSource® or MapInstall®. Both these applications are available
from Garmin®.
The MapSource® application is a viewer utility that allows
one to browse maps created for Garmin® GPS. It also
allows many other functions associated with your Garmin® GPS of which the
most important are:
• Load new maps to your GPS
• Download tracks and waypoints from your GPS to your PC
• Upload tracks, waypoints and routes from your PC to your GPS
• Route planning, especially with routable maps since MapSource® can
simulate the auto routing algorithm of you GPS.
MapSource® is not sold separately and is integrated into Garmin®’s map
products. However, if one installs any of the Garmin® map products, the
installer will first install MapSource®.
The easiest way to obtain a copy of MapSource® is to simply buy the new
Garmap DVD. These DVD’s are sold at around R10. If your GPS was purchased
after 1 April 2008, then you are entitled to a free upgrade to the 2009 version
of Garmap. Ensure that your GPS is registered with Garmin before you start
the installation process.
If you insert the DVD to your PC it would automatically bring up a wizard that
would take you through the install procedure. This procedure requires
Internet access and on-line registration of the product. In some instances it
would also require additional payment.
Once you have installed MapSource®, simply install T4A GPS Maps and then
open MapSource® and select the T4A GPS Map product you wish to use."
2006 4.8 GL
1994 4.2 SGL
Metalian Mini
Bundutop on each
Return to “20. Comms”
