Tent Pegs
- davejones
- Full Name: David Jones
- Nickname: David
- Home Town: Lagos, Nigeria
- Been thanked: 5 times
Tent Pegs
Gentlemen
I'm going to spend a week camping in Tankwa Karoo at the beginning of May.
The ground is believe is extremely hard. Wondering what kind of pegs to use. I've been advised to try out rebar, but may just stick to your camping outlets.
Dave
Dave
An ox, but with balls !!!
- Jorrie
- Full Name: Jacobus Jordaan
- Nickname: Jorrie
- Has thanked: 184 times
- Been thanked: 165 times
Re: Tent Pegs
Maak net die grond 'n bietjie nat 'N rukkie voordat jy die tentpenne wil inslaan. Dit werk.
- Bruin Beer
- Full Name: Riaan Delport
- Nickname: Rooian
- Has thanked: 6 times
- Been thanked: 21 times
Re: Tent Pegs
Dave,
Consider a battery powered drill and a ling concrete drill bit
Good luck.
Enjoy the camping
Bruin Beer
Good luck.
Enjoy the camping
Bruin Beer
- davejones
- Nickname: David
Re: Tent Pegs
ive got MAKITA
- Has thanked: 800 times
- Been thanked: 549 times
Re: Tent Pegs
dave
Take a piece of rebar 10mm and weld a handle on it like a small t use it to fist go in and twist it out on the t. Then knock your tent pen in the hole
- Stefan
- Nickname: Stefan
- Has thanked: 175 times
- Been thanked: 49 times
Re: Tent Pegs
Our local Steel shop has plenty of rebar cut-offs and they sell them for R10/kg, go and have a look, or give them a call - you may be surprised
- Russ Kellermann
- Has thanked: 8 times
- Been thanked: 93 times
Re: Tent Pegs
Dave,
I went to Afrika Burn last year and did exactly that. I took re-bar and cut them into pieces about 200mm long, then i ground down the one side to make a sharp edge. I took more than i needed and i bent about 2 or 3 of them, the ground there is no frikkin joke dude.
The best yet is if they can weld a little T on top of each one, then you dont have to go in at an angle and the tent will NEVER blow away,.....because in the tankwa if your tent starts to blow away you will NEVER EVER get it back,..... I saw a couple tents fly past me during the massive storm, including a huge markee tent, ....they were never found..... i then saw a few upset woman coming to terms with the fact that they no longer have a place to sleep in. hahaha.
The cordless drill and a long bit just smaller than the re-bar is actually a bloody good idea and will save you time and energy (ie: Drinking hours).
Enjoy the camping. Let me know if you coming near CT bro ok!
- davejones
- Nickname: David
Re: Tent Pegs
thanks for the advice
- Jorrie
- Nickname: Jorrie
Re: Tent Pegs
Someone please help the sailor. What is re-bar?
Re: Tent Pegs
Jorrie dis konstuksie staal daai rondes met riwwe op ie kant baie harder as ggewone round bar
Users browsing this forum: No registered users and 23 guests
