2000 4.2d Patrol failing alternator
EFH
Full Name: Elmar Henning
Nickname: EFH
Home Town: Bloemfontein
Current 4x4: 2000 Nissan Patrol 4.2d GL
Home Language: Afrikaans / English
Post by EFH » 10 Feb 2018 20:03
So seems my Patrol has a dying alternator. Had belts changed for roadworthy and now its dying, all the classic signs, weird warnings, fading headlights etc. Other than agents where can I look? Autozone ?
Ag kak.
Burnco Replacement Bumper, Suspension Lift, Terrain Taimer 'erd
Picasso
Full Name: HS
Nickname: Picasso
Current 4x4: Nissan Patrol
T3 Syncro
Home Language: German
Has thanked: 11 times
Been thanked: 43 times
Re: 2000 4.2d Patrol failing alternator
Post by Picasso » 10 Feb 2018 21:16
I guess one would take the alternator out and have it rebuild / refurbished which should cost between 1000 - 2000 R... :mytwocents:
EFH
Nickname: EFH
Post by EFH » 10 Feb 2018 21:25
I was thinking that, but would you ever really trust ut again?
Picasso
Full Name: HS
Nickname: Picasso
T3 Syncro
Post by Picasso » 10 Feb 2018 22:38
yes
Has thanked: 113 times
Post by hugejp » 11 Feb 2018 00:02
I have done 80000km on a refurbished unit so far...
Go for it.
:mytwocents:
Has thanked: 292 times
Been thanked: 111 times
Post by Kagiso II » 11 Feb 2018 00:29
mine did the same. At Elliot I had to find a workshop, Thank The Lord I found the right people ... chop chop the found the positive wire on the alttrntr has come loose [not off, just loose ]
Tightened it and iNyathi was good to go, did it once again .. I tightened the nut and since is going A 1
Has thanked: 307 times
Been thanked: 379 times
Post by Peter Connan » 11 Feb 2018 06:51
EFH wrote:
10 Feb 2018 21:25
Yes, as long as the job is done properly.
Don't just fix the immediate problem, but do a full overhaul. New bearings, brushes and regulator unit.
Has thanked: 569 times
Been thanked: 295 times
Post by Tinus lotz » 11 Feb 2018 08:59
Mabe your new belt is loose ?
EFH
Nickname: EFH
Post by EFH » 11 Feb 2018 10:33
I checked the belt, tightened it slightly, I'll check the wires on the alternator. Got a jump from a fellow camper this morning, drove 45km, now tick tick tick when trying to start immediately after switching off. Luckily I stopped on an incline, so I'll try bump start when I leave.
Post by Tinus lotz » 11 Feb 2018 12:48
Beste is maar om te meet
