Fuse/Relay diagram
mattk
Full Name: mattk
Nickname: mattk
Fuse/Relay diagram
Post by mattk » 11 Apr 2016 15:00
I have searched the forum, but do not seem to find a diagram of where which fuses/relays are. I was specifically looking for the aerial motor fuse. Normally your handbook show this, but I find the Patrol handbook to be rather thin on actual information. :think:
Has thanked: 515 times
Been thanked: 250 times
Re: Fuse/Relay diagram
Post by Tinus lotz » 11 Apr 2016 15:21
Got no idea... :think:
Has thanked: 188 times
Post by ricster » 11 Apr 2016 15:36
Please dont do this..... but short it out and look which fuse blew..... :rolling: :rolling:
Post by ricster » 11 Apr 2016 15:38
I also have no clue. I pulle the plug off under the fender when my aerial kicked the bucket. Fitted a bee-sting type in its place. works brilliantly.
Post by Tinus lotz » 11 Apr 2016 15:46
Matt your arial is 10 to 1 dead.....there is a plug that you can test on under the cover....
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 17 times
Been thanked: 74 times
Post by David M » 11 Apr 2016 15:48
Blew mine a while ago.
It is one of the fuses under the dash on the driver's side. Know it took me a while to find it as it was not marked "power aerial" or suchlike. Using a test light is quickest.
roelf prinsloo
Full Name: Roelf Prinsloo
Nickname: Roelf
Home Town: Klerksdorp
Current 4x4: nissan patrol 4.8 grx 2014
Been thanked: 5 times
Post by roelf prinsloo » 11 Apr 2016 16:34
Ek het n kompleet motor as jy belangstel , die antenna is stukkend maar ek het ook die part no.daarvoor was R750 n ruk terug.
mattk
Full Name: mattk
Nickname: mattk
Post by mattk » 11 Apr 2016 18:11
It is going to Graham to be sorted, as it is a rather odd issue: when I switch on the ignition, the aerial will go up halfway, then have to press the 'extend' button. If I press the 'retract' button, it will retract halfway. I have to switch the ignition off to get it in completely. Obviously, this is a no-no in the bush.
ricster wrote:.... but short it out and look which fuse blew.....
: brilliant idea, will have the fire brigade and insurance company on standby. And collect my 'idiot of the year' award tomorrow (unless Numba Wun beats me to it....) :blonde:
Picasso
Full Name: HS
Nickname: Picasso
Current 4x4: Nissan Patrol
T3 Syncro
Home Language: German
Has thanked: 9 times
Been thanked: 35 times
Post by Picasso » 11 Apr 2016 18:21
ricster wrote:I also have no clue. I pulle the plug off under the fender when my aerial kicked the bucket. Fitted a bee-sting type in its place. works brilliantly.
To Cedric:
What is a Bee-Sting ? :think:
Is it one of those short ~ 30cm thin steel rods ?
Post by Tinus lotz » 11 Apr 2016 18:40
Matt just purt a bee sting 75 rand later flexable rubber like the ones we use to mount on the roof of the golfs
No need for expensive stuff you can put that half way up switch to good use....... :mytwocents:
