35" tyres are rubbing
Buddy
Full Name: Daniel Smit
Nickname: Buddy
Home Town: Vredenburg
Current 4x4: '18 Ford Ranger Wildtrak 3.2 Auto
'03 Nissan Patrol 4.8 GRX Auto
Has thanked: 5 times
Post by Buddy » 29 Sep 2018 13:23
Good day Gents,
I have noticed that under full steering lock the driver side tyre rubs against the inside of the fender, but the passenger side does not touch.
This is on normal road, and will be a problem when hitting the trails.
Is something maybe wrong on the DS suspension setup? Alignment?
Before I start trimming inner wheel arches, maybe there is another way.
Regards, Daniel
nisjeep
Full Name: Peter Church
Nickname: Nisjeep
Current 4x4: 2002 Patrol 4.5
2001 Terrano 2
Been thanked: 6 times
Re: 35" tyres are rubbing
Post by nisjeep » 29 Sep 2018 14:15
Daniel
That's normal for the GU. Problem is with axle sideshift during compression and rebound. Look at the angle of your panhard rod and that will explain why the driver side always rubs first.
A quick fix is to turn the stopper out on that side. Or fit a body lift of 30mm or higher.
Job done
