Patrol Pickup - Suspension lift options.
- Full Name: SJC
- Current 4x4: 4.2 GQ (TB42)
- Has thanked: 199 times
- Been thanked: 173 times
Re: Patrol Pickup - Suspension lift options.
Doen hulle nie net shocks nie?
- offroadbiker
- Full Name: Dirk de Clerk
- Nickname: ORB
- Home Town: Krugersdorp
- Has thanked: 186 times
- Been thanked: 262 times
Coil over shocks ... gaan kyk net, ek het dit op my Isuzu gesit en dit was die moeite werd gewees en defnitief ondr R10k vir voor en agter.....
- offroadbiker
- Nickname: ORB
As ek reg onthou het dit my 'n 30mm lift gegee en ry kwalitiet was baie beter. Het ook balljoint flip gedoen en schakels verleng. En dis ongelukkig hoe ver my kennis in die area strek...
- Full Name: SJC
Well, uhm..... if money was not an issue: https://www.superiorengineering.com.au/ ... er=135,355
"Superior 4-5 Inch Lift Kit Nissan Patrol GU (Leaf Rear) with Tough Dog Shocks
Superior Engineering has put together the ultimate heavy duty level 4-5" inch suspension kit to suit the GU Nissan Patrol (coil front and leaf rear).
This kit includes the following Superior and Tough Dog 4WD Suspension Components:
2 x Coil springs front
2 x Leaf springs rear
2 x Front 45mm Tough dog Big Bore Adjustable shocks (BMX1047/6)
2 x Rear 45mm Tough dog Big Bore Adjustable shocks (BMX1206/4)
1 x Tough dog EXT Steering damper
2 x Super flex Arms (2x Superflex plates 2xM16/100mm bolts 2x M16/90mm bolts 1xM14x100mm bolt & Nut 4x M16 Nylocks 1x Crush
Tube 2x M16 fine Thread nuts)
2 x Extended brake lines
1 x Extended diff breather kit
1 x Extended brake proportioning valve bracket
2 x Damper brackets (pin-pin)
2 x Extended shackles
4 x U bolts C671
2 x Pin to eye adapters
1 x Bush kit UK719
1 x Front Panhard
2 x Rear fixed pins GR667
1 x 4140 Drag link"
$5,439.00 (Aus dollar) = +/- R58k
4 x U bolts C671
1 x Bush kit UK719
1 x Front Panhard
1 x 4140 Drag link"
- Has thanked: 800 times
- Been thanked: 549 times
Krisis....my bakkie het 60k gekos..... en ek het n suspension by gekry.....
- Been thanked: 155 times
Gents... I have heard alot of people speak and readva lit what people wrote on SUSPENSION upgrades and/or changes In my humble opinion one of the moste knowlegeable on Suspension is Mr Robert Hale of DUNE OFF ROAD.
They are the agents for CALMINI Suspensions but he goes far beyond that and they design and manufacture self.
Contact Robert at O 84 58O 8 eleven 4. You welcome to say i pasted him here...And get his opnion and maybe even a quote.
It wont bevlike 58 K from Ozzland for sure.
- Full Name: SJC
Daai R58k is wel vir 4-5" lift met al die benodighede...
Om 'n Patrol bakkie se suspensie lokaal te vervang met OME, TJM, ens.(2" lift), is by die R30k+....
- Has thanked: 49 times
- Been thanked: 241 times
SJC wrote:Daai R58k is wel vir 4-5" lift met al die benodighede...
There is a big difference in requirements between a 4" lift and a 2" lift.
The list mentioned by Fanus are the extra stuff required. Not worth it, unless you buy a model that already has it in (like Dirk's GQ from Grant).
But then look at what Christo Boegman does with hardly any lift, which begs the question if any money spent on lift is worth it...
- Full Name: SJC
Increasing the vehicles height aka lift, also increases the approach, break-over and departure angles...
Not saying 4" is the way to go, but 2" does help a bit.
This might be true on a patrol wagon, but I think the pickup needs all the help it can get...Alex Roux wrote:
- Full Name: SJC
Hulle het nie agterste shocks vir die patrol bakkie nie. net voorstes. (R3500 vir stel).offroadbiker wrote:Wat van Camil suspensie??
As ek so vinnig kyk na die pryse en kwotasies wat ek die laaste klomp maande ontvang het. Gaan dit omtrent 7k kos om shocks te vervang.
(Bilstein is bietjie goedkoper).
TJM - R7k
Bilstein, - R6k
RAW suspension - R6.6k
Ironman - R7.4k
So, indien enige van julle moet besluit tussen hierdie fabrikate, wat sou jy kies?
(P.S. Ek is baie gelukkig met die TJM wat in my 4.5 is....)
