Oil splashes in wheel arches
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 446 times
- Been thanked: 670 times
The Patrol was washed on Wednesday, and I was out in Swartruggens over the weekend. When I got home, I found that the front and back wheel arches were coated in a very thin film of, what appears to be, oil. Only on the right hand side, and there was more oil around the back wheel arch than the front.
I can not work out where it comes from. I've been through everything. I see no leaks anywhere, and all fluid levels are perfect. So about the only assumption I can make is that I must have driven through a patch of oily water... But I cannot remember driving through any water since the truck has been washed...
Can "die manne wat ken" perhaps point out something I may have overlooked ? Diff breathers maybe ? Do they come out on the right hand side somewhere ? If so, why would the be pushing oil out ?
ORRA: H80
ORRA: H80
- Been thanked: 468 times
Re: Oil splashes in wheel arches
Difficult to guess mate, but I would wash it off and after a good few Km check again if there is the same splashes. As its on both wheels, it may be that you drove over some oil patch on the road. Check under the Patrol for any telltale signs of a leak. It will be quite a leak if there was enough "oil" to coat both the wheel arches!!
- iandvl
- Nickname: Ian
Cedric,ricster wrote:Difficult to guess mate, but I would wash it off and after a good few Km check again if there is the same splashes. As its on both wheels, it may be that you drove over some oil patch on the road. Check under the Patrol for any telltale signs of a leak. It will be quite a leak if there was enough "oil" to coat both the wheel arches!!
Thanks - that was my thought - ie: anything dumping that much oil should be relatively easy to spot. But there is nothing. Nada.
I just cannot remember driving through any oil, water, anything since Wednesday. Yes, we were out in the bush, and the vehicle was in low range on two occasions, but the veld is as dry as anything out that side. Personally, (and especially since I'm not doing river trip ) I would have appreciated some mud... :)
I'll clean the splash marks off this evening and keep an eye on it.
ORRA: H80
ORRA: H80
- bogeyman
- Full Name: Christo Boegman
- Nickname: Chris
- Current 4x4: 2005 4.8 GRX
'95 patrol 4.2 (now 4.5) sgx plus four 4.2 diesel p/u plus 3 safari workhorses. - Home Language: Afrikaans
- Been thanked: 91 times
Ian,
Stop driving behind Land Rovers.
From what I read , it must have been something on the road, Maybe diesel.
If there is no oil spill under the car where you park it , don't worry.
- Full Name: Ian Temperley
- Been thanked: 92 times
Hay Christo, stop picking on us Landy Lovers, we don't leak oil we just mark our territory!!! LOL
hahaha.... Your Landy better go to the proctologist, cause that's far too much leaking.... oops sorry marking of territory going on
- iandvl
- Nickname: Ian
Thanks for all the feedback everyone. Nothing under vehicle and similar. I'll stop worrying now. Appreciate the responses.
ORRA: H80
ORRA: H80
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
maybe when you had your car washed and they put that shining polish on the tyres ,it comes of and leaves a nice oil ring in the wheel arches...??
- Has thanked: 1067 times
- Been thanked: 987 times
My feeling is that any leak from the vehicle that gets deposited inside the wheelarches must be flung by the tires.
If there is no oil on the inside surface of the tires, then it's not coming from your car.
If there is oil on the inside surface of the tire, it could probably only be diff oil or brake fluid...
