Dipstick for 4.8 auto
Pieter B
Full Name: Pieter Botha
Nickname: Pieter
Been thanked: 32 times
Post by Pieter B » 05 Jan 2018 06:57
I've ordered a dipstick for my 4.8 from Atlantis Nissan in Centurion. Unfortunatly it will only arrive in a months time. In the mean time I made up a dipstick from dimensions I got from a post on the Forum. I made the dipstick from a piece of plactic fibre tubing. But when I used it, I'm not getting any oil on it. So my first question is: can somebody please confirm the length. My info is that it's 568mm long.
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Swakopmund Namibia
Current 4x4: None
Has thanked: 85 times
Been thanked: 96 times
Re: Dipstick for 4.8 auto
Post by JoshJ » 05 Jan 2018 15:24
Pieter ek het n dipstick vir auto box. Sal vir jou meet as ek by die huiskom nou nou
Being alive is a Blessing!!
Joshua
JoshJ
Nickname: Joshua
Current 4x4: None
Post by JoshJ » 05 Jan 2018 18:29
Pieter it os 755mm from the sholder to the tip. And the max full when hot is at 730mm. Hope this helps.
Joshua
Pieter B
Nickname: Pieter
Post by Pieter B » 05 Jan 2018 21:42
Dankie. Dit verduidelik hoekom ek niks olie op my "dipstick" kry nie
JoshJ
Nickname: Joshua
Current 4x4: None
Post by JoshJ » 05 Jan 2018 21:46
Net so.. :thumbup:
Joshua
Has thanked: 109 times
Post by hugejp » 06 Jan 2018 08:24
What does the dipstick cost at the stealers??
JoshJ
Nickname: Joshua
Current 4x4: None
Post by JoshJ » 06 Jan 2018 09:42
Cant remember the exact price but was around R200.
Joshua
Pieter B
Nickname: Pieter
Post by Pieter B » 06 Jan 2018 12:02
R300......
Post by hugejp » 06 Jan 2018 12:14
Pieter B wrote:
06 Jan 2018 12:02
R300......
Hi Pieter,
Have you recently bought one?
Do you possibly have the part number?
Pieter B
Nickname: Pieter
Post by Pieter B » 06 Jan 2018 16:00
The dipstick was ordered from Jacques at Atlantis Nissan in Centurion. Part no.11140VC20A. Maybe you should hold of a little until I received mine. Let's check first to see if it's the correct part.
